Thinking of making switch, inform me! 2013 6.7 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 11-12-2018, 07:29 PM
Grss429
Grss429 is offline
Grss429 is starting off with a positive reputation.
I have a 08 tundra, I love it but I just found a deal on 2013 f250 xlt 4wd with 100k miles for 26k, what should I be worried about? Or things to check, it does need a rear bumper/hitch it's all bent (no frame damage) other then that it seems clean, check engine light was on he claimed low battery voltage and would have it fixed at Ford before bought.
It was a work truck
Old 11-12-2018, 08:42 PM
Superdave71
Superdave71 is offline
Superdave71 is gaining momentum as a positive member of FTE.
Iím gonna guess itís been abused. I would personally take it to a ford dealership for an evaluation. They possibly could run an Oasis report to give you details of the warranty service record.
It it would take ALOT to bend a trailer hitch on one of these trucks. Be careful.
Old 11-12-2018, 08:51 PM
Grss429
Grss429 is offline
I'm a technician, I can check it out and get a report run, to be honest seems like a idiot didn't know how to back up a trailer
I definitely want proof they fix the CEL, might even scan it myself, they claim its battery related due to it dying on the truck, its Texas truck
Old 11-12-2018, 08:59 PM
senix's Avatar
senix
senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
it would be a night and day different truck and experience. As long as you really look it over closely, radiator seams, all exhaust components in tact and coolant color and oem fuel and oil fiters. I'd consider it.
Old 11-12-2018, 09:01 PM
Grss429
Grss429 is offline
if filters aren't OEM I'd definitely be putting them in coolant suppose to be gold color?
Old 11-12-2018, 09:38 PM
senix's Avatar
senix
senix is online now
Yes on the coolant color
Old 11-12-2018, 09:50 PM
djousma
djousma is online now
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
Check the hour meter. If idle hours are more the 10-15% of total hours, I'd probably pass. These trucks with all the exhaust filters are not meant to do a lot of idling like old school diesels
Old 11-13-2018, 05:49 AM
Grss429
Grss429 is offline
thanks will take a look
Old 11-13-2018, 07:22 AM
djousma
Correct me if Im wrong Scott, but in this year 6.7L, the coolant is Orange?
Old 11-13-2018, 08:23 AM
senix's Avatar
senix
senix is online now
That is correct but sometimes It appears different best to look into it
Old 11-13-2018, 08:39 AM
dirthawg's Avatar
dirthawg
dirthawg is offline
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
MY11-18 6.7L gets orange coolant VC-3. Didn't they switch to gold in 18 or 19. I understand the Gold coolant is a relatively new coolant.
Edit: 2019MY Gets Yellow Coolant VC-13 according to the owners manual.
Old 11-13-2018, 10:01 AM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Painted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant future
The coolant color can vary. Yes they call it Gold, But after 50,000 miles in an engine, it can be red, brown or something between. Color doesn't mean it bad.
Get the test strips and do your little chemistry test and see if the coolant is good.
The coolant was rated for 105,000 change interval under normal use. or 60,000 under severe use.
Old 11-13-2018, 01:22 PM
djousma
Joel, Are we talking about what came stock in the 2013's? Or what came in your 2017? AFAIK, it's always been called Orange in the 2011-2016's.
Old 11-13-2018, 01:32 PM
Vet3138
Vet3138 is offline
Vet3138 is starting off with a positive reputation.
I second this. I bought a used '13 with 1400 hours on the idle meter because the truck was spotless and never towed heavy, rookie mistake. I have replaced egr cooler, egr valve, vacuum oil lift pump gasket, CAC hose, and I just finished replacing the primary radiator this weekend. Truck has been a blast.
Also if you can try and get the DPF checked, had mine checked the other day and dealer said it's 35% restricted.
Old 11-13-2018, 08:26 PM
dirthawg's Avatar
dirthawg
dirthawg is offline
I wouldn't be worried about a bit of idle time as long as it wasn't excessive like 40-50%, 10-15% idle time is a highway truck. My truck has 24% idle time and it is ran on the highway 40% and city 60%. Instead make an offer that would reflect replacing the EGR cooler and valve.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
