Adding Overload Springs to an F250 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 11-12-2018, 02:26 PM
Stinson1
Stinson1 is offline
Stinson1 is starting off with a positive reputation.
Hello, I just added a service body to our F250 Lariat Super Duty 6.7 4 door short bed. The truck seems to handle the weight well, but the back is sagging slightly. I would like to level the truck back out.
Our truck being an F250 does not have the Overload springs and pads. I am thinking about adding these. Has anyone done this with the factory ford parts? Another option would be aftermarket add a leaf/superspring or bags, both I would like to avoid. I did swing by the dealer to look at a 350 and a 250 side by side. F350 is 4 Leaf plus overload and F250 is 3 leaf. It appears I need: Overload spring, overload spacer, overload frame contact pads/brackets, longer ubolts, longer center spring.
Thanks
Old 11-12-2018, 07:43 PM
7591250sd's Avatar
7591250sd
7591250sd is offline
7591250sd is starting off with a positive reputation.
Just get the camper package parts, the parts diagrams show all the parts. This is mine with about 2500 lbs 5ver pin weight, about 3 in of sag.
Old 11-14-2018, 07:36 AM
Stinson1
Stinson1 is offline
Thank you 7591250sd, would you be able to provide me with your spring code? It should be on your door jam sticker. I think I just need to figure out which spring code I need to order.
Thank you for pointing me in the right direction
Stinson
Old 11-14-2018, 01:39 PM
7591250sd's Avatar
7591250sd
Here yah go, holler if you need anything else.
Old 11-15-2018, 05:03 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is online now
ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.
Get a set of leafs from the junkyard and make your own add-a-leaf kit.
Old 11-15-2018, 06:34 AM
dtaylor1
dtaylor1 is offline
dtaylor1 is starting off with a positive reputation.
I used this kit on my F150. And I have installed a couple at work on F150 and F250 trucks. It's a great kit.
https://activesuspension.com/
Old 11-15-2018, 08:14 AM
Stinson1
Stinson1 is offline
I think that is kinda where I am at at this point. I think I will just pull my leaf pack apart and throw an additional leaf in and a longer center pin. The U bolts look plenty long to handle an additional leaf.
Thanks
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
