Modular V10 (6.8l)
2005 passanger side cam replacement
Old Nov 12, 2018 | 08:39 AM
Firstn10's Avatar
Firstn10
Guys,
i've been lurking for some time now just reading all the old posts trying to gain knowledge for my first v10 2005 f350 160k.
I got a ticking on the passenger side and pulled the valve cover off and lucky me the cam is shot. Got new lifters, rockers and passenger side cam on the way but I have a few questions if you can help.
1.) I think I need a new bolt to hold the gear onto the cam right?
2.) Can I just pull the cam and replace all the lifters and rockers then sequentially tighten the bolts down a little at a time to install. or do I need to do like the manual says and leave certain rockers out and then install after torqueing down the cam?
3.) anytips you can think of to save me some grief while doing this?
Probably have more Questions but I sympathize with all who have worked on these in the engine bay(Tight).
Thanks in advance!
Love this sight!
Firstn10
Old Nov 12, 2018 | 08:54 AM
johnfist's Avatar
johnfist
I just did this a few weeks ago on my 2008. I couldn't get the rockers to reinstall with new cams doing it the way the factory manual shows. I did however, remove the specific rockers before removing the cam.
I put all the lifters and rockers back in, then put the cam in. It's a bit tricky because everything is aluminum and you don't want to mess any threads up, but it's doable.
As for the front bolt, I only replaced mine because I rounded off some of the edges getting it broken loose. The new bolt will not be the same size as the old bolt, just FYI. You don't really need a new bolt though.
Don't forget to soak your lifters overnight.
You'll also need two specialty tools, the rocker removal tool specific to the 3V Triton, and the timing wedge tool. Both are necessary.
Oh, and removing most of the ignition wire harness makes getting the valve covers on/off easier. Also don't forget to scrape off the rubber gasket material from the front seams of the heads and replace it with high heat liquid gasket before you put the valve cover back on.
Old Nov 12, 2018 | 09:52 AM
Firstn10's Avatar
Firstn10
Thanks for the quick response John!
I watched your videos (wish I had a lift like you) you kind of skipped over the cam install so I didn't get a good feel for it.
I and lots of others appreciate you taking the time to make the videos. Keep up the good work!
and thanks again.
Firstn10
Old Nov 12, 2018 | 12:18 PM
johnfist's Avatar
johnfist
and thanks again.
Firstn10
Hm, I haven't made any videos myself. I've posted some from youtube a few times. My truck is a plain jane XL work truck haha. Anyway, I'll check back on the thread in case you have any issues.
Old Nov 13, 2018 | 05:36 AM
tiffy2000's Avatar
tiffy2000
for those who have had bad cams what weight oil have you run ? Seems like Ford recommended going to 5w-20 and I have read it had something to do with the cams not getting oil quick enough
Thanks
Old Nov 13, 2018 | 07:29 AM
johnfist's Avatar
johnfist
Thanks
I run whatever the truck cap or manual specifies. They redesigned the rocker arms so that the lifters deliver better oil compared to the old design.
edit: I don't know what years the trucks started coming with the new rockers, but my 2008 had the old ones.
Old Nov 13, 2018 | 11:16 AM
Firstn10's Avatar
Firstn10
I ran 5w-20 but only had the truck about a month before it craped out... so no telling what previous owners did.
Firstn10
octaneforce
24
Feb 18, 2011 11:15 AM
Greenmachine_76
Jan 29, 2009 08:04 PM
ThunderTim
Feb 27, 2007 05:06 PM
austynn2001
Aug 27, 2006 12:43 AM
FlairSide
Apr 11, 2006 11:08 PM
