52 f3 dakota swap (D)
Old 12-12-2018, 05:30 PM
thepitshop's Avatar
thepitshop
thepitshop is offline
thepitshop is a splendid one to beholdthepitshop is a splendid one to beholdthepitshop is a splendid one to beholdthepitshop is a splendid one to beholdthepitshop is a splendid one to beholdthepitshop is a splendid one to beholdthepitshop is a splendid one to beholdthepitshop is a splendid one to behold
Thanks!! , Cruiser
Old 12-12-2018, 06:46 PM
56panelford's Avatar
56panelford
56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Does the wife have you on a curfew on this build Gil...lol
Old 12-12-2018, 08:36 PM
thepitshop's Avatar
thepitshop
Big time!! Can't get anything done
Old 12-12-2018, 09:37 PM
56panelford
Posting Legend
Looks as though you're making pretty good progress just the same..
Old 12-16-2018, 07:35 AM
thepitshop's Avatar
thepitshop
Worked on guage placement this week,unfortunately I had to mount them ''roadster'' style center of dash, there was just not enough room in the reg location, also filled all the other holes, just have to add a lense and mounting hardware ,a little bodywork
and I'm done!
Old 12-18-2018, 08:36 PM
thepitshop's Avatar
thepitshop
Bought some slightly used 20 inch rims
Less center caps
Old 12-23-2018, 02:38 PM
thepitshop's Avatar
thepitshop
Built and installed a set of inner rockers yesterday, cleaned and box lined all underneath, firewall and inside the cab this morning.
Old 12-24-2018, 11:33 AM
thepitshop's Avatar
thepitshop
Box lined under and in cab, painted frame,just have to wet sand top part of firewall to try and match rest of truck
Old 12-24-2018, 11:50 AM
EBEAR's Avatar
EBEAR
EBEAR is offline
EBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to behold
Comeing along nicely .
Old 12-24-2018, 04:13 PM
pineconeford's Avatar
pineconeford
pineconeford is online now
pineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant future
I think you have posted the biggest shop I have seen on here in 10 years.
And yes, you are making big progress. To be able to accomplish so much in these particular weeks of the year, I'm impressed. Tom
Old 12-26-2018, 07:09 PM
thepitshop's Avatar
thepitshop
Thanks, I'm borrowing a stall where I work!
Old 12-26-2018, 07:12 PM
thepitshop's Avatar
thepitshop
Today installed the cab,installed the heater-a/c box,wiring harness, receiver driver bracket.
  #28
Old 01-03-2019, 06:44 AM
thepitshop's Avatar
thepitshop
Tin back on,cut and moved the front dakota front mounts, made brackets and used stock dakota front mounts,made a rad support and installed rad and condenser, made a fuse box bracket, now just waiting on heater vents so I can work on the dash.
  #29
Old 01-03-2019, 07:48 AM
Ct70
Ct70 is offline
Ct70 is starting off with a positive reputation.
How does the track width seem to be ? Does the newer Dakota frame have the splice in it like the older ones or s10 so you can easily alter the wheelbase ?
  #30
Old 01-04-2019, 06:13 AM
thepitshop's Avatar
thepitshop
05 and up dakota's are wider than 04 and down but this will work, the frame itself is way better than the s10, fully rectangular,way heavier built, you got rack and pinion, front is wide enough that you dont need spacers like the s10, a rear end that will handle V8 power, there is a spot on the frame that looks like it's been joined but I have no idea, if not,the center section is straight so it can be cut and spliced anywhere, now I've done both, the ''bang for the buck'' is the dakota frame.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
