Truck stalled out while driving - Ford Truck Enthusiasts Forums
Old 11-09-2018, 09:59 AM
smithrock's Avatar
smithrock
smithrock is offline
smithrock is gaining momentum as a positive member of FTE.
2002 F-250 7.3l I was driving my truck the other day, and while driving- it shut off! A little scary when in traffic and your power steering tightens up and you're trying to make to the side of the road!
Could not get it started after- it would crank, but not turn over. I checked fuses- they looked good. Ended up having it towed home. I checked, it appears that it's getting fuel. I did check the starter relay, I pulled it out and tried the fan motor relay- it started for a second- then died. Put the starter relay back in- started for a second-then died. At his point I'm at a loss. Any ideas?
Old 11-09-2018, 10:05 AM
PrescottIce's Avatar
PrescottIce
PrescottIce is online now
PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.
Check engine light? Any codes?
Old 11-09-2018, 10:07 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
BillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to behold
What kind of reaction are you getting when trying to start?
As in - WTS light working correctly? RPMs bouncing when cranking or no? Any smoke from tailpipe when cranking and what color if so.
With all the cranking, also be sure that your batteries have MORE than enough to crank it over. IIRC the truck requires a min 10.8 volts just to fire the injectors.
When you said it just shut off, my first thought was Fuel bowl heater but you checked fuses so that would of included the 30amp that powers the ECM & heater.
Not likely but an easy check/fix, check ALL connection to and from the batteries. Both ground and power. Clean any and all corrosion you may see. I had a no start issue awhile back and replaced batteries, starter etc. Finally did the cleaing bit and found that the corrosion on the solenoid terminals were causing my no crank.
I am sure others will reply soon with other options. Hang in there.
Old 11-09-2018, 10:14 AM
Sheldon Plankton's Avatar
Sheldon Plankton
Sheldon Plankton is offline
Sheldon Plankton has a good reputation on FTE.Sheldon Plankton has a good reputation on FTE.Sheldon Plankton has a good reputation on FTE.
Originally Posted by smithrock View Post
2002 F-250 7.3l.... I checked, it appears that it's getting fuel.....
Does that mean that you saw fuel in the fuel bowl? The fact that it starts then dies sounds like fuel starvation to me. Can you hear the fuel pump running? Is the filter black and sludgy looking?
From my personal experience, the truth is that if you're not monitoring fuel pressure, you don't really know that the truck is "getting fuel".
Old 11-09-2018, 10:25 AM
smithrock's Avatar
smithrock
No codes.
Batteries around 11.2 (after all the cranking). I did check those 30amps- all good
Yes, I did see fuel in the bowl- but you are right, I don't actually know if it is getting fuel. I feels like it's not when i try to start it. Frustrating!
Old 11-09-2018, 10:29 AM
BillyBob69's Avatar
BillyBob69
No codes.
The injectors are oil driven so dont forget the IPR on the back of the oil pump. I haven't personally seen this issue but I know it seems to be a common one. Tin nut on the back of the IPR being loose.
Old 11-09-2018, 11:20 AM
smithrock's Avatar
smithrock
That tin nut could cause the vehicle to stall when driving? Had no idea! I'll check it when I get home from work.
Old 11-09-2018, 08:41 PM
smithrock's Avatar
smithrock
So I got home, figured Id try and start it- it started right up. I did have a trickle charger on the batteries overnight.
I let it run for a min or so in the driveway. Seemed fine. I now have the check engine light. The code is a P1280.
Old Yesterday, 02:18 PM
'88 E-350
'88 E-350 is online now
'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.
Did it die suddenly like someone turned the key off, or did it loose power and sputter out? What's your fuel level? If it's below 1/4 and the fuel pick-up foot is broken, fairly common, it can suck air. If it sucks air enough to die while driving it can take quite a bit to purge all the air out of the system and get it going again. Even when it starts it might have low power for a while 'till all the air is worked out.
Old Today, 09:50 AM
axmrdr
axmrdr is offline
axmrdr is starting off with a positive reputation.
A bad ipr will act like that. Works when it cools down. Dirty oil caused mine to go out before I found out how important it was to change oil often.
How's the oil level? Low oil will cause a stall.
Broken fuel foot mentioned but it will miss some before dying. Did it sputter?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
