F250 5.8 Rough Idle Problem
Got this truck not too long ago, when I got it, it had a check engine light for 2 things, TPS sensor, and another sensor I forget the name of, but is vacuum actuated. After replacing those 2 my check engine light went away but I'm still getting a really rough idle. Too rough to just be engine mounts, but they are definitely getting torn up from the shaking. The ticking that kind of sounds like a misfire is because of a crack in the exhaust manifold, not sure if that could cause an idle this rough by tricking the egr system? Plugs and wires are new as well as all of the normal matenince stuff, only other thing I can think of to replace is injectors but wanted to see if anyone else had this problem before I put money in the wrong places. It's not a surging idle like I've seen some people have with their 5.8's and 302's, the rpms stay pretty steady but it just shakes the whole truck like crazy. I will post a video of the shaking below. Oh yeah, I also thought maybe 1 cylinder was low on compression, I didn't do a compression test yet so I'm not 100% certain, but I put a bottle of engine restore in it, everyone that I have seen use this stuff it solved all of their low compression issues. With it in the engine now there is not the slightest difference in the way it runs.
Is it smoking at all ?
How did the new spark plugs look ?
Exhaust leak fixed yet?
Spark plugs looked great, no smoke whatsoever, none of the plugs looked burnt at all, just one of them had a little oil on it, but I'm just assuming oil is getting passed that one valve stem seal, which is an easy fix. And nope, haven't gotten the manifold fixed yet, thought I'd do a compression test first to see the state of the engine, I thought those numbers were too low, seeing as some people have 5.8's with 140-170psi. Maybe they were just really well taken care of. Guess I'll buy a new manifold and see the results here soon.
Well, 140-170 on a new engine or new rings and a valve job maybe, but not on a 1989...
How many miles on your engine?
Your valves are probably leaking a bit, but if they were really bad you would get some backfiring.
You could use a better video, showing the entire engine compartment.
Doesn’t look like it is shaking much from your video, but hard to tell.
How does it run at highway speeds?
I would block off the EGR-Valve from the intake by sliding in a solid gasket made out of metal sandwiched in-between two regular gaskets.
