Dually rims - Ford Truck Enthusiasts Forums
Dually rims
Old 11-08-2018, 06:08 PM
264WSM
264WSM is offline
264WSM is starting off with a positive reputation.
Dually rims
What are the specs I need to have for a spare set of rims?? All I know is that it is an 8 lug metric pattern. I do not know the offset either.
I would like to buy a set of 17" or 18" rims for my 2000 F-350 Dually
Also, what rear diff do I have?? I'm wanting to get a posi unit.
Old 11-08-2018, 06:31 PM
DieselDenny
DieselDenny is online now
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Grab a flashlight and a wire brush. There's a tag on the dif that's hard to read. Scrub it down and post. I'll try to find the chart and get it to you.
Denny (btw, friend just switched to alloy and sold his set of six) Sorry
Old 11-08-2018, 06:43 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
Assuming you have a 99-03 you have a D80.
Here’s a link with the specs, I put these on mine. https://rover.ebay.com/rover/0/0/0?m...2F252046283322
Here’s a link to the Truetrac I put in mine: https://rover.ebay.com/rover/0/0/0?m...2F300964506398
Old 11-09-2018, 12:53 PM
Shovelheadrob's Avatar
Shovelheadrob
Shovelheadrob is online now
Shovelheadrob has a good reputation on FTE.Shovelheadrob has a good reputation on FTE.
If you're looking to change the diff be aware that if you have 3.73 gears you actually need a 4.10 carrier as Ford used a slim 3.73 ring gear on a 4.10 carrier. Not all suppliers show this!
Old 11-09-2018, 04:57 PM
264WSM
264WSM is offline
Not looking to regear, just add a posi unit to the back. If I am pulling a trailer I usually have to chain up to get up my driveway in the winter. When I "posi-ed" my F-250 Sterling 10.25", it helped a lot in the winter.
I'll check out the links and when it gets warm I'll pressure wash the diff off and look for a tag. It was 7* this morning.
Old 11-09-2018, 05:11 PM
Shovelheadrob
What gear ratio do you have at the moment? If it's 3.73 then you need the 4.10 & up carrier. The Dana 80 is used in Dodge & GM trucks too but only Ford did this peculiarity.
Old 11-11-2018, 09:48 PM
264WSM
264WSM is offline
Yup, it's the 3.73
Old 11-11-2018, 10:17 PM
Colorado350
Yup, it's the 3.73
‘If you’re not going to regear this is the part you need: https://www.justdifferentials.com/TT.../tt915a567.htm
Dont forget new ring gear bolts, probably rebuild kit too.
Here’s the same part on eBay but cheaper and taking offers: https://rover.ebay.com/rover/0/0/0?m...2F253915132238
Old 11-12-2018, 09:57 AM
264WSM
264WSM is offline
I'm gonna need to work this into my budget. I'm guessing I'll have $1200 into it by the time I'm done.
What oil do I use?? 75w-90 or 80w-140??
Old 11-12-2018, 10:45 AM
Colorado350
I used the heaviest weight I could find 90w/140 IIRC. Yeah that’s about right, my gears, rebuild and install was $800, Truetrac was $250
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
