THE BEST UPGRADE FOR A V10 IS:
Gears are ok, but transmission upgrades are a better solution in my opinion.
1 to 3 hours and a few hundred dollars can have custom valve bodies installed.
30 minutes and a few hundred will have a custom program installed.
That's 75 to 80% of the task.
clutches and converter can wait but at 1st oprertunity they should be installed.
I live at 7800 ft and my V10 is 20% down on power because of that. That is basically a 5.4L power out of a V10.
With 5-star tunes loaded (and the accompanying increase in shift pressure), my tranny shifts VERY FIRM with even moderate skinny pedal. Like to the point where I sometimes worry about U-joints. I can't imagine driving this thing with stock software having owned 5-star for years now. It's easily been the best relatively low $$$ upgrade I've done.
Has anyone ever tried the PCS transmission controller?
I see it is a complete transmission programming suite. You can tune transmission just like some people tune a pcm.
pricy at $750 though.
https://www.powertraincontrolsolutions.com/Performance_Aftermarket/Products/Transmission_Products/TCM2800_Transmission_Controller/A-TCM2800/
most of 5 stars tune is for the transmission not the engine.
even they realize the transmission is the key upgrade.
As far as 5Star realizing that the trans is the key upgrade, I don't think they sell any gear upgrade packages. . They, as a TUNING company seem to focus on the tunes and items that directly impact the tunes, like intakes and headers. I think downstream items like gears are outside their wheelhouse as a tuning company, that shouldn't be taken as meaning that a nice tighter shift strategy (with no additional trans gears or ratio changes) is superior to improved final drive ratios. I've got both (plus good headers) and the gears were hands down a bigger performance increase than the tunes (which are very nice), no question about it.
I don't see how a stronger and tighter trans rebuild that doesn't add any new gears or change any internal ratios can bring that additional performance, better drive ability sure but where exactly is the performance gains coming from? But hey, you seem convinced that a well built TC and trans are the hot ticket to better performance, so go ahead and prove me wrong. . I have another five years of heavy towing in front of me with my EX and may need to deal with the trans at some point, so I do look forward to seeing what you can do with yours.
Not have the 5 speed
Not sure if everyone on here has the auto trans but I cannot stand my 5 speed (or should I say 4 speed who uses first). Worthless peice of crap going up hills empty. I got k&n and exhaust but still seems weak on hills. Any suggestions? Just ordered a chip and was thinking on getting headers but something tells me that won't be enough...at all.
My 99 F250 165k miles with 4" cat-back Exhaust, SPD Y-pipe and 5 star Performance tunes moves great with no slippage feel like OP is describing. Believe me, I don't baby my vehicles either.
I need to get my Thorley Header's installed. I bet it will roast the tires.
See if 5 star can set you up with a Tuner and header's.
Which gears do you have?
A chip? They still sell chips for these? What you want is a tuner like Coop said above, and 5Stat Tuning (site sponsor and the go-to guys for 6.8 custom tunes) will write a set OD custom tunes for how you use your rig. However with yours being a stick you won't get the best part of the tunes, far better Auto trans shift strategy, but you will get the better engine response and the little bit of engine output the tunes supply.
As has been said many times before (by most here.....) GEARS are the single biggest performance improvement you can do for your V-10, what are you running now?
#29
Ya I have 35's looking to get 37's soon. Just seems like the truck is weak up hills without pulling anything. What gears would you recommend?
#30
My Ex runs 35"s and it has 4.88s, it is our dedicated tow rig for an 11K+ TT and it handles that big trailer very well, will go up most Eastern Interstate Highway grades at over 60 MPH in OD, its not what I would call weak going up those hills at 19K+ lbs combined, unloaded its pretty sporty.
