Having problem with driver's side door lock
Old Nov 8, 2018 | 03:00 AM
eagle275's Avatar
eagle275
Put key in trying into lock to unlock will not turn. It will turn to the right kinda hard, turn to the left it's stuck. may break key off inside lock if I put too much pressure on it. It does it a few days then has stopped and works fine, this may be the last leg. What would cause this and how can I fix it? Thanks!
Old Nov 8, 2018 | 07:24 AM
jas88's Avatar
jas88
Do you have power door locks? Could be the actuator. Could be the door latch assembly. Could be the lock cylinder. Hard to say.
Old Nov 8, 2018 | 08:36 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What he said. You need to remove the door panel and disconnect the linkages to the latch until you find the one that is binding up the lock cylinder.
Old Nov 8, 2018 | 10:09 AM
CamoF-250's Avatar
CamoF-250
have you tried a little graphite in there too?
Old Jan 4, 2019 | 07:22 AM
eagle275's Avatar
eagle275
Ok have manual locks
Old Jan 4, 2019 | 08:21 AM
My4Fordtrucks
I know time goes by fast.....there are a bunch of things I haven’t gotten to do but it literally takes 10 minutes to remove the door pane to see what is binding up. It’s been 2 months since you were asked if you had power locks.
Old Jan 4, 2019 | 09:55 PM
eagle275's Avatar
eagle275
Yeah I know My4, but not long after that found out I had prostate cancer, they caught it early just having radiation. But I'm good still working out at Y and I should be cured. Im just getting caught up again. Anyway, thanks, I know you telling to not be so slack, but this old retired career combat soldier of 25 yrs had to take care of that. I had planned to get right back on my projects but,....But hey bro that
nks for getting me back on track, much appreciated bud!
Old Jan 5, 2019 | 08:00 AM
My4Fordtrucks
I know a couple people that have been cured of prostate cancer. Hopefully doing projects around the house will keep your mind focused on other things. Get well soon!
Old Jan 5, 2019 | 08:25 AM
subford's Avatar
subford
Has someone moved the door striker.
If so the door may not be all the way closed for door latch assembly even if the door looks closed.
This will keep the key from unlocking the door.
Mine did that last year and I had to move the striker to get it to work.
Old Jan 7, 2019 | 10:53 AM
CamoF-250's Avatar
CamoF-250
I now wonder if replacing my striker made mine stiff. Unfortunately, I did locks and strikers the same day. The old door lock was fine but I got a set with the new ignition switch. I need the weather to warm up and the sun to hang around a little longer to inspire me to get after my amounting required repairs, troubleshooting and projects on this truck.
smashclash
Jan 3, 2012 02:15 PM
Hunt4Fun
Aug 17, 2008 10:26 AM
Duffy_wuffy
1983 - 2012 Ranger & B-Series
Nov 25, 2004 09:32 AM
elspode
Jan 5, 2004 08:03 PM
