Transmission leak - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > Bronco II
Reload this Page >
Transmission leak
Bronco II Ford Bronco II
Transmission leak
Old 11-07-2018, 03:30 PM
2010Imperial
2010Imperial is offline
2010Imperial is starting off with a positive reputation.
Transmission leak
Hi all,
I am new here and in need of assistance. I have an '89 Bronco II that is leaking fluid from the transmission dipstick tube. The 2 piece tube came apart, so I don't know if it is coming out of the actual tube, or leaking from the rubber seal that holds the tube in the trans. If anyone has ran into this problem please chime in! I was going to pull the whole tube assembly out and replace the gasket, and weld the 2 tube pieces together. But my fat hands don't like it up there. Thoughts?
Old 11-07-2018, 04:11 PM
Roxette's Avatar
Roxette
Roxette is offline
Roxette is starting off with a positive reputation.
Hi all, I think you have to go out full tube of the gauge, it is not easy but it is possible. When you have it in hand you will be able to judge what is best to do, whether you repair it, or you mount another in good condition.
Friendships.
Bye
Roxette
Old 11-07-2018, 04:27 PM
2010Imperial
Thanks for the reply. I am confused on what you mean by "go out full tube of the gauge"?
Old 11-07-2018, 04:34 PM
Roxette's Avatar
Roxette
Roxette is offline
Disassemble to the vehicle. Unbolt the bracket on the gearbox near the cylinder head and check the o-ring that fits into the crankcase of the gearbox.
Friendships.
Roxette
Old 11-10-2018, 11:44 PM
McLeod's Avatar
McLeod
McLeod is offline
McLeod has a good reputation on FTE.McLeod has a good reputation on FTE.
I don't know for certain, as I have no B2, but my guess is there is a failed o-ring in the dipstick tube joint
Old 11-21-2018, 04:23 PM
2010Imperial
Got the dipstick tube out. But, I can't feel the o ring from the outside. Do I have to drop the pan to get to it?
Old 11-22-2018, 11:19 PM
Roxette's Avatar
Roxette
Roxette is offline
No, normally not, the o-ring should be on the tube, but maybe it's gone in the crank case, in which case it's better to remove the crankcase to see if it's in it.
Good luck.
Old 11-24-2018, 04:45 PM
2010Imperial
Does anyone know where to buy a 1 piece dipstick tube for an '89 Bronco II?
Old 11-24-2018, 05:47 PM
Roxette's Avatar
Roxette
Roxette is offline
Hi All,
Amazon.com, Ebay.com or a crashed car park.
Old 11-29-2018, 04:40 PM
2010Imperial
Is there not a "gasket" that goes in the dipstick hole? Or is just a rubber o ring that goes on the dipstick into a metal hole? Thanks
Old 12-02-2018, 10:15 AM
Roxette's Avatar
Roxette
Roxette is offline
Hi All,
The gauge tube is in two parts, one part is on the gear box, the second part is in the first one, there must be an o-ring every time one enters the other.
You should find in the trade this kind of set, there are all sizes:
Old 12-02-2018, 10:46 AM
Roxette's Avatar
Roxette
Roxette is offline
Hi All,
https://www.mycloud.ch/l/L006C07BD64...91CFC186131433
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
