HPOP Non-Serviceable plug replaced, now only 300psi - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 11-08-2018, 03:25 PM
TheBigBee's Avatar
TheBigBee
TheBigBee is offline
TheBigBee is a splendid one to beholdTheBigBee is a splendid one to beholdTheBigBee is a splendid one to beholdTheBigBee is a splendid one to beholdTheBigBee is a splendid one to beholdTheBigBee is a splendid one to beholdTheBigBee is a splendid one to behold
You are correct 500 PSI is ICP for start.
Here is the minimums for starting.
OTHER NO START OR HARD START ISSUES When trying to diagnose hard start or no start issues a scan tool is needed to check and monitor the ICP (Injection Control Pressure), RPM (From the CMP) Vehicle Voltage during cranking and PW (Pulse Width) signal.
1. RPM, minimum 100 rpm cranking speed (When warm it should be over 180 rpm)
2. ICP, minimum required for starting 500 PSI if no rpm signal, ICP won’t go over 400 PSI
3. Voltage during cranking 7-10 volts minimum depending on year
4. Pulse Width; 0 ms means no sync, 1994-1997 .42 ms indicates that PCM and IDM are in sync (on 99-03 it should be .60 ms) and the PCM is waiting on the ICP to reach the minimum of 500 PSI. When min. ICP is reached PW should change to 1-6 ms
5. If any of the above doesn’t meet the minimum specification, solve the problem as-per the appropriate Ford Diagnostic Manual.
Old 11-08-2018, 04:43 PM
Everlanders's Avatar
Everlanders
Everlanders is offline
Everlanders is gaining momentum as a positive member of FTE.
Originally Posted by timmyboy76 View Post
Anyway of tryn anutha ipr?
I don't have a spare IPR...
The Ford Dealer says all his Canadian warehouses are out of stock for two weeks.
The Local International dealer has one in town, but they want $450 CDN
I'm considering getting one from a local Auto Wrecker - Can they "wear out"? There is nothing really to wear on the insides is there? Once you clean out the gunk and install new o-rings it should be fine?
I did clean this one out, but now I see this article which warns against crushing the pilot valve body, I did use vice grips with folded up shop towel to open/close the IPR... Perhaps I crushed the valve body? Has anyone heard of this?
Old 11-08-2018, 05:08 PM
Everlanders
Or do I dare get the NAPA brand for $269 ??
https://www.napacanada.com/en/p/DNQIPR200#
Old 11-08-2018, 05:20 PM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
Dont waste your money on aftermarket it will create more headaches.
Can you get this shipped to you ?
https://rover.ebay.com/rover/0/0/0?m...2F201405915698
Old 11-08-2018, 05:28 PM
Everlanders
yes, but mostly no...
"We do not directly ship internationally. We only ship internationally through the Ebay Global Shipping Program."
Which means they ship it to an American facility who then reship it to Canada... It take 3-4 weeks in my experience.
Old 11-08-2018, 05:33 PM
Colorado350
Does EBay have Canadian based sellers that may have the IPR on your side of the Border?
Old 11-08-2018, 05:49 PM
Everlanders
It's Laughable... There is one knockoff for 170.95
Old 11-08-2018, 06:41 PM
PrescottIce's Avatar
PrescottIce
PrescottIce is offline
PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.
Someone around here will have one for you to borrow - maybe post up a new thread asking to try a known good one. If I had a spare, I'd be on my way to the post office already.
Old 11-09-2018, 11:33 AM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
Old 11-12-2018, 10:29 AM
Everlanders
Originally Posted by duck fan View Post
Riffraff ships to Canada
Yes, I've ordered from Clay a few times, and have just placed another order for an IPR. It should be here in a few weeks time.
On Saturday I pulled the IPR again in case I got some debris in there... I took some zoomed in photos of the tiny pin, I assume it acts like a needle valve and that 45 face should be smooth and flat but mine has cupped in that face.
Old 11-12-2018, 03:25 PM
Bonanza35
Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Well I hope you found your problem. Please report back and let us all know how it worked out. Could save someone else.
Old 11-12-2018, 03:26 PM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
I agree with him ^, this has been puzzling to say the least and we look forward to hearing good news from you in a couple of days.
  #28
Old 12-08-2018, 01:29 PM
Everlanders
Bad news boys.
​​​bad news everyone, I finally got the IPR here in Canada 3D printed a 12 point socket and installed it in the truck moments ago, it started after about 15 seconds of cranking and after I got it good and hot, I shut it off and immediately tried to start it. After about 10 seconds of cranking it started up again. After 10 minutes of letting the oil pressure dissipate, it won't start.
Exactly the same as before.
I suppose the next step is to pull the valve covers and watch for injectors puking oil?
  #29
Old 12-08-2018, 07:17 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
AllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to behold
I hate that it didn't solve your problem but am impressed with "3d printing a socket"
  #30
Old 12-09-2018, 05:26 PM
Everlanders
Found the problem!
After replacing the IPR, I was still only getting ~600psi ICP @ 85% IPR duty cycle. (when cold, it would have started if UVCH were connected.) But not when hot.
Trying to find a way to deadhead test the pump, my buddy found some acorn lug nuts that had the same thread as the fitting in the heads, so we cut off the end of one of them and plugged my old ICP sensor in, isolating the pump. 650PSI...��
So I yanked the pump for the 3rd time and sent in the borscope, but it was hard to say for sure if the ball was there with the plug in place. So I pulled the plug and sure enough the ball was there. Used a pick to spin it around... Seemed fine. But it wouldn't come out... Tried tipping it over and tapping the body, nothing. Cleaned the oil out really well and zoomed some photos, we saw a green fillet on the one side of the ball. Picked away at it for quite a while and finally got it freed. Chased the threads on the body and the plug and put it back together and let the 680 cure overnight.
Useing some soft silicone tubing pressed up against the small hole on the face of the pump, I blew and sucked and could hear and feel the ball clacking back and forth. It didn't seal 100% when dry but with oil it's probably fine.
Today we put it all together and it fired right up.
TL;DR
Don't glue the ball in place. Test that it's free and use the hose suck/blow test after your Lock tight has cured.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
