Blueberry is mine
Blueberry is mine
So, I've purchased a '98 Club Wagon Chateau 4.6 L V8 with the 4 speed OD transmission. Substantial down got us at 0% interest for 12 months at $100/mo.
Going to be doing a full service on this just as funds allow.
I have a few things in mind right away, but they'll have to wait.
The only nits I've found so far are PDL internal switches are dodgy, probably just a ground issue I suspect. Other than that it drives out well.
Great news for us!
Great news for us!
When the PDL switches start acting up I've found removing them from the connector and cleaning the small contact pins helps quite a bit. Also inspecting the contacts in the connector body to make sure they're making good contact is also helpful.
Usually when a switch has failed it won't work at all, not intermittent. Not a huge issue but aggravating none the less.
Thanks JWA I've seen this fix on Jeep CJs as well. On my next days off, I'll have a closer look. Along with headlights bucket search. The remote went nutz today too. Got some fresh batteries but to no avail. The drivers side control panel for windows, mirrors and door locks was ajar so I suspect that a good a place to start as any.
The RKE (remote keyless entry) module if factory will be behind the driver's seat on the side wall, just a few inches behind the B-Pillar. If a Club Wagon it'll be behind the interior trim---not the easiest access to be sure.
Here's what I found for EVTM's:
Complete WSM printed set: 1998 WSM Complete Set
EVTM only: 1998 EVTM Not in the best condition but still usable.
I've also purchased complete WSM's on CD-ROM which require temporarily re-setting your computer's system clock in order to use them---not all that inconvenient if you really need or want the info.
HTH
HTH
HTH
HTH
The ground is contained in the wiring harness, an EVTM will show which physical point that ground is connected to the chassis or frame.
WOW! Thanks so very much JWA 😊
I've been remiss in posting photos I'm sorry to say. What with the employment upheaval I had to deal with a little more than a month ago. I went from a always on hard line high speed internet connection, to strictly relying on my old cell phone who's camera is not the best. Once I get it figured out I'll be a photo posting nut.
once this fix is all said and done I've got the headlight conversion planned, also installing the Bosch 'Jumbo' fog lights and the backup alarm I pulled from that pos Suburban I once had.
If by "armrest switch" you mean the door mounted switch cluster then no its not physically grounded to the door shell---any ground connection will be found in the wiring harness leading from the door to the body.
If you're still working on intermittent PDL's then your issue probably is not a fault in a single ground wire. This is where the EVTM's are invaluable.
