Blueberry is mine
I can dig that, thanks again JWA 😊After, wiring up an electrical radiator fan while introducing a Ford PDB with fuses and full sized Bosch relays, to control it with switch for automated, defeat and override as well as relaying the headlights, fog and driving lights. Soldering the whole works, and using this terrific 3M adhesive lined heat shrink tubing. I really enjoyed that project and at the same time I converted the battery/starter wiring to welding wire.
after all that I think I found a new hobby.
I pulled the mid seats and the interior panel, easy as cake, just like the Monogram models of the '70's. Found the box and the wiring seems nominal. No sign of where this box grounds, took the back of the box off and the psb seems okay, no sign of burnt circuits or anything. It's hanging loose pending whether someone can point me to the ground or if it's not unusual that the black box has as internal fault.
The conclusions of my diagnosis is that somewhere in the wiring of the Hornet alarm system there is some weak wiring connections using those damnable wire taps.
I suppose I'll have to not only purchase the Ford manual for electrical but also the corresponding manual for Hornet alarm systems.
The RKE is intended to work WITH the PDL's, its not intended to be the one and only way to lock/unlock the doors---I'm sure you know this already. I'm fairly confident even if it fails completely the PDL's will work through the switches. The remote could be an issue but as it only comes into play when attempting to trigger the RKE it shouldn't cause the intermittent PDL operation you're describing.
If you do get an EVTM I'd completely remove this potential hack job installation of an after market alarm to restore the factory wiring. If you want another alarm get a newer model that includes installation instructions along with on-line support. I'm personally using a very old skool model known as Crime Guard 350i---long since replaced with "new, improved" versions that don't offer me anything of interest function-wise. Those are dirt simple to install and operate---it really seems the lack of complicated BS added courtesy of "the digital age" increases reliability and reduces complications.
HTH
Well, I headed out to Hab in hopes of finding a derelict breaker panel for the grounding bus bar as I did for my Jeep. No go there so I headed out to the wrecking yard and actually found all of the parts to convert the headlights to sealed beam and for only $17.00
Once I get going on this I'll post a how to with photos.
#30
