86 E350 24 Camper Fuel Pump - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 11-05-2018, 08:25 AM
Number4
Number4 is offline
Number4 is starting off with a positive reputation.
Getting as titled, but with a bad fuel pump. Probably bad gas too.
the camper portion will have been removed, so Im guessing fuel pump access will be easy. Thoughts?
86, E350 with the 460/C6 and carbd.
From what Ive read, it has more than one pump, including in-tank.
1. If I install an in-line electric pump, would it pull through the others? Anyone done this?
2. Could I run it off a gas can instead? I just need to be able to move it 3 miles from a storage yard to my place.
Old 11-09-2018, 11:43 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
moose4x4 is starting off with a positive reputation.
1. It should pull through the others if screen in tank is not plugged. But the gas possibly being bad, not a good idea.
2. I have used a boat tank strapped to the roof before. could run it through the mechanical pump if it has one or, straight to the carb and it will gravity feed carb once you put fuel in the line running into the hood. It won't have as much speed with the gravity flow but it will work.
Old 11-10-2018, 12:34 PM
Brnfree's Avatar
Brnfree
Brnfree is offline
Brnfree has a good reputation on FTE.Brnfree has a good reputation on FTE.
My fuel pump is going south and I’m fixing to drop the tank this weekend.
https://www.ford-trucks.com/forums/1...tarvation.html
You should be able to deliver gas the the carb with an external tank as previously suggested. If you have an assistant they could squeeze a boat gas primer bulb to actually pump gas to the carb.
The circuit that supplies power to the in tank fuel pump is rather complex. Sure it’s the pump and not a wiring or some other issue, like the fusible links, inertia switch, oil pressure switch, fuel pump relay, or fuse #18?
Ulimately, after all this time, you’ll likely have the drop the tank to clean it out. I suspect I’ve got some sediments in the bottom of my tank.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
