Understanding ECM / PCM
ANCIENT ECM
I wonder if the ECM is bad on the 89 E150 I just bought. Has high idle problems along with charging problem. I put a new alternator on it after the original one failed the bench test. New one failed the on vehicle testing, yet it passed the bench test, indicating a wiring or other on vehicle electrical component failure. Has anyone else had this issue? Is there a way to test these units as a whole or is it something I should just replace, as it is 30+ years old. I hate to start throwing parts at a vehicle I have no knowledge of it's history. At least I got it for a good price.
For those who are still wondering and are still unsure, the PCM or ECM whichever one you want to call it is directly underneath the blower motor in the front passenger's side of the van. it is held by 1 bracket secured to the blower motor housing together with a ground wire. the front end of it which goes toward the fire wall is where the electrical connections are which is held by a 10mm bolt which can be removed from under the hood. you have to remove the battery for better access to the 10mm bolt.
Many Thanks for all the replies, For those of you following this thread :
After replacing the IAC, ECT, MAF, fuel pump, fuel filter, fuel regulator, distributor with new plugs and wires , new exhaust ( cat back ) and testing the TPS, I still have a rough idle when cold ( truck runs much better when at temp )
I will clear and re pull the codes in a couple of days, but for now I am stumped ...
How much money and time do you have invested so far?
If you have one bank running lean I'd think a leak in the intake manifold. You may have a vacuum line leaking or weak/clogged injectors. Would be odd for one bank to be weak/clogged though. Have you put a vacuum gauge on it to see what it reads? You may need to goto Harbor Freight and get a cheap mechanics stethoscope for that noise at shut-off.
Here are the codes it is throwing , after clearing the memory by disconnecting the battery :
KOEO : 11, 18, 33
KOER : 44, 33
I do have the ERG valve removed and the port blocked off with a steel plate, there is also a device that I bought off of e-bay that plugs into the connection for the EGR to keep the engine light off ( but I have no clue how it works ) the vacume line is plugged with a small bolt.
I will try to get to harbor freight for a vaccume gage sometime this coming week .
KOEO : 11, 18, 33
KOER : 44, 33
thisismary
10-10-2015 02:28 PM
