Cleaning an oil bath air cleaner
Old 08-12-2008, 02:10 AM
Mike-fire32's Avatar
Mike-fire32
Mike-fire32 is offline
I just pulled the air cleaner off my 534 expecting to be able to pull it apart and clean the filter element, but it appears the top section does not come apart. What type of element is in there and how do I clean it?
Mike
Old 08-12-2008, 06:21 AM
boggerted's Avatar
boggerted
boggerted is offline
The way I clean oil bath cleaners, although it might not be the best possible way to do it, is:
1. Pull the bottom bowl off
2. Depending on the style, there may be removable screens stacked on top of each other. Separate them and clean them with brake cleaner or other similar product.
3. Dump out old oil and clean any sediment out of the bowl.
4. If theres other baffles in the housing that arent removable, just spray some cleaner in there and let it drip out.
5. Finally, reassemble with fresh oil
Old 10-04-2017, 07:13 AM
Mrwaynecounty01's Avatar
Mrwaynecounty01
Mrwaynecounty01 is offline
What
Mike
what does your air cleaner look like for your 534? In looking for one for mine
Old 06-30-2018, 07:39 PM
baddad457's Avatar
baddad457
baddad457 is offline
I used to rinse them out with good ole gasoline. More effective and cheaper than using brake cleaner.
Old 10-13-2018, 06:55 PM
Hotrod350's Avatar
Hotrod350
Hotrod350 is offline
IGNORE ME, Wrong thread
F250Rob
44
10-11-2017 08:49 PM
460jared96
02-18-2017 08:51 PM
bruno2
08-30-2016 06:39 PM
DetailerDave
1999 to 2016 Super Duty
07-07-2016 04:34 PM
Nannook of Texas
03-23-2016 05:41 PM
Quick Reply: Cleaning an oil bath air cleaner
