Jag IFS swaps
So far on the jag I had located on clist, they won’t reply. Irks me for an ad to show but no reply after 3 calls and 2 emails.
Rant over.
Im looking at other options one is Lexus if I can’t find a jag which appears to be the best/easiest install.
Guess I will finish rebuilding my 302, anything out of spec and it becomes a 331.
Thanks for the info and I will keep searching
Rant over.
*****, Folks,
I see 2 xj6 with in 200 miles of me (NWPA). One in Michigan at $700 and one for 1200 not sure where. So I guess they are out there, Just maybe not in your area at this time. No I am not planning on this any time soon But will this same jag IFS fit the 52-56 for frames? Also What are some of the major things that problem ares to watch for and other parts needed to complete this swap? Also see folks say that they rebuild these first. Is that pricey too. This must be a pretty cost effective option compared to buying a "kit" set up in a nice neat package?
Sorry for the questions and I am not even building a truck, but I do file this information away!
Regards,
Chris
Regards,
Chris
Chris,
Others have put the Jag in post 1952 Ford trucks. There is a little more work required since the 48-52 truck frames are "pinched in" from the 34" width to 32" width in the engine bay. This means altering the frame or the crossmember of the Jag to get it to fit in the later trucks since they are a constant 34" frame width.
Chris,
B
Rant over.
Rant over.
$400 is a good price. That's what I paid for my 79 Jag XJ12. I used the IFS and IRS, wheels, gas caps, powersteering pump and brackets, and a few interior pieces. I sold a few parts off the Jag and scrapped the rest. You can buy ball joints, tie rod ends, and reman rack and pinion gear from Rock Auto (on line). Brake parts are available from most parts houses and poly bushings are available from Energy Suspension. Ebay is also a good source. If you soft mount don't forget the lower steering shaft. I used part of the steering column too.
Hope this helps.
Dan
Hope this helps.
Dan
#29
#30
Hi Bjorn,
Checked out your site, nice build you have going on there. Very professional. Beautiful truck.
Yes, I do drive a four wheel drive, actually have five of them. But that is not my intention on my 56. I liked the looks of fellow member Aussie 53's build and how he placed the Jag ifs on his 53 f100. He was kind enough to answer some questions I asked him via email about it. I checked out his build photos closely and used them as a guide.
Three reasons I did it this way: 1. I wanted the soft mount. Pages of discussion on soft vs. hard mount in the H.A.M.B. lots of opinions both ways. I like the soft mount better. 2. I want the truck lower than stock but not too low, this is the height I wanted. 3. The inner fenders do not need to be cut, the upper A arms will not be visible in the engine compartment. A lot of extra work I suppose, but to get it the way I want it I don't mind.
Best Regards,
B
Best Regards,
B
leewiffen
07-24-2011 11:07 AM
aussie1
05-23-2007 08:24 AM
JoeSwing78
07-21-2005 09:53 AM
Kenny
11-14-2003 06:25 PM
64 f100
03-14-2002 11:41 PM
