One trip hauling with out EGT gage?
Think I know the answer but....... So i went and bought a building in Licking Mo. where I will be moving the shop to by the first of the year. The down side is ive had to completely drain the bank account to make it happen. With moving expenses and all the last minute BS I really am strapped. It looks like I will be making several trips between San Diego and Mo. pulling a 20’ trailer. If I old man it and go slow and easy is an egt gauge really necessary the first trip? I need real life advice here, not the 20/20 in a perfect world, money is no issue answer. Thanks guys its appreciated,
My opinion,
Assuming your truck is running the way it should and given the mods I see in you signature, I wouldn't hesitate to do it.
I think you know your truck well enough to drive it conservatively and not get near the upper limits of the EGT range.
If your really concerned, disconnect your tuner.
Thanks guys, about what I was expecting to hear. It is on the short list of projects but my usual procrastination... oh well! More than the cash im out of time to even work in the install. Moving a shop cross country is a major PITA! Thanks for the replys it helps settle the mind with one less thing to think about. Appreciated!
Well I'll give my real world experience, vs perfect world dreamers. No boost leaks, Towing our 5th wheel using Gear Head's 2 "Tow" tunes on a TS6 the EGTs hover at 1k on a very slight incline, any obvious hill and I'm watching the EGTs like a hawk and lifting my right foot to keep them at 1240, or I'm down shifting, or even dropping into "stock" tune to keep temps in check. Even in stock form if you keep it floored in 6th on a good hill you'll see 1200.
Also, EGT and the water temp gauge? No, not even. After 5 minutes of towing the factory coolant temp gauge stays the same, my aftermarket EGT and oil temp gauges move rapidly based on engine rpm/load vs coolant pretty much stays in the middle without moving
Keep the RPMs up when it isn't completely flat and tunes off and you should be ok with no gauge
Read about and saw photos of the carnage? Lots.
Combustion chamber temps can rise very quickly. Eventually that heat transfers through the cylinders and heads to reach the coolant, and eventually that coolant will start to heat up the sensor. By the time the coolant temp gauge rises to alarming temperatures the pistons, or other parts, might be wrecked. I've read of this happening with both gas and diesel engines repeatedly.
Stop and let the truck cool is NOT the thing to do. Drop speed and downshift to reduce load and increase coolant and air flow. If that fails to reverse the rising temperature you stop as a last ditch effort.
