Font Axle Seal? How Big of a deal is this?
So I was poking around under my 06 F250 this weekend and look at what condition I saw what I believe are the front axles seals popping out? I will attempt to add pictures for your reference and advise as to who I should have fix this, what exactly is wrong and how much should I expect to pay. Also is this a big deal? I have no idea how long ive been driving like this. what can happen if left alone?
]http://
]http://
Yes. Or cut them off but you'll be hard pressed to look under any of our trucks without seeing the signature "axle hula hoop." You could take the time to replace it, but you'll be frustrated when the new one pops out in a few weeks time as they're known to do.
Your right guy's and I actually took permatex black and spun a small bead all the way around those boots and pushed them back in let it set up overnight and that was six months ago and they are still in . Try it
But more so is look at your front axel u-joint, that cap is solid rust not much grease in those. What do you guys think?
They have a newer version of the dust seal ("hula hoop") that is actually better. You have to remove your axles to replace them so there is no reason to go through any of that just for the dust seal.
I tore my front end apart a couple of years ago for inner oil seals and installed the "new style" dust seals then. They are still holding together.
Everything eventually fails. I've had my axle out a few times and the new dust seal was a hula hoop in short order. This new version that I used last time is still intact 3 years later (50K+ miles).
Nicmike
09-29-2020 03:20 PM
dpilot83
1999 to 2016 Super Duty
01-01-2016 12:34 PM
