Moog lower ball joints failed 30000 miles
Old 10-28-2018, 11:40 AM
SSStang's Avatar
SSStang
SSStang is offline
About 30000 miles ago I replaced most of my front suspension. Last week I purchased new tires and rims. So I dieceded to get the wheel aligment check. The guy comes back and says my lower ***** joints are bad. Sure enough there bad.
I have a 2.5 leveling kit on the truck and 34s but now im running a 31 tires.
I thought Moog was a good brand.
Any suggestion on replacement lower ball joints?
Old 10-28-2018, 01:45 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is online now
Motorcraft.
Old 10-28-2018, 05:40 PM
SSStang's Avatar
SSStang
SSStang is offline
I guess I’ll try motorcraft this time hope they last!
Anyone try mevotech?
Old 10-28-2018, 07:28 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
IMHO, always use "professional grade" if listed separately...Moog is one company that does have different grades....avoid thermoplastic materials as well.
Old 10-29-2018, 09:55 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
They used to be until they sold out, now Moog is made with Chinese steel, not American.
Old 11-17-2018, 09:17 AM
SSStang's Avatar
SSStang
SSStang is offline
So finally had sometime to swap the lower ball joint. Ends up passenger upper is bad too! MOOG SUCKS!
Went ahead and ordered motorcraft upper control arms with the bushings and ball joints. So next week ill swaps those out and take it back to have wheel aligment checked.
Old 11-17-2018, 10:29 PM
woopud's Avatar
woopud
woopud is offline
The problem is your leveling kit, I assume it's the spacer in the strut/spring assembly? The sharper angle between the lower control arm and hub assembly put too much stress on the ball joints, been there done that...
Old 11-20-2018, 02:54 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,288 Likes on 1,089 Posts
OEM ball joints ... and ditch the leveling kit. My trucks original 275/55-20s are over 31".
Old 11-21-2018, 10:20 AM
Beechkid's Avatar
Beechkid
Beechkid is offline
I agree, with you definitely have to do your research on the products....as an example, when I rebuilt the front suspension on my wife's Sport 2 years ago... I went with Moog professional line...… no thermoplastic and they were made by TRW..... the same company that builds MC replacement parts....at least for that model....
joe blow
1999 to 2016 Super Duty
04-10-2011 11:19 AM
MadMedic20
10-17-2010 08:58 PM
Ford4dog
1997 - 2003 F150
10-28-2008 10:03 PM
Fat Ford Boy
1997 - 2003 F150
12-20-2005 06:11 PM
dieself3502001
09-29-2004 07:42 PM
Quick Reply: Moog lower ball joints failed 30000 miles
