Truck just shuts off
My guess is somewhere to or from your ignition switch (or maybe replace the switch itself) there is a wire that needs replacing. Go through them all and see if there is an easy one to spot that is loose, melted, or sitting against something that gets hot.
There is a good thread on the wiring here...
https://www.ford-trucks.com/forums/1419663-diagram-for-ignition-switch-wiring.html
Final answer?
So the other morning at 28 degrees the truck wouldn't start. Turn the key on and no start, no crank, radio was on so assumed coil would be powered. Had a spare igntion switch( the round one you put the key in), quick and easy to plug in and the truck fired right up. Left it just hangin under dash as i drove to work just fine, about 45 mins. After work i pluged the bad one back in and it started right up this time............ Gotta be the switch?
on
1 Post
"the round one you put the key in" is not the switch. That attaches to the switch. The switch is then plunged into the wiring. If you still have it hanging under your dashboard I'd spend about 20 bucks and put a new switch in My ignition switch was doing the opposite of yours. The truck would start and run but the accessories wouldn't work. New switch fixed my problem and I suspect it will yours as well
bcrimmins
06-04-2018 10:02 PM
bulldogcountry1
09-21-2009 10:57 AM
projectdagger
32
06-18-2007 02:08 PM
