Hangovers, dirty mirrors, and leaf-spring rub - Wheel specs!
Main benifits is when you install new tires you already have the beads installed.
Can't help with wheel/tyre issues but I ran dynabeads on 22' rims on my old Roush supercharged F150 & was very impressed with the results. I'm going to go with the Centramatic rings on this truck though as I consider it to be my forever truck & it's much easier to use the rings over trying to gather up the ceramic ***** when it's time to change tyres or get a puncture fixed.
Do us a favor and post up how those work out after running them a few hundred miles.
I get mine done at the local truck shop and they dismount my tire to put the beads in and honestly I don’t know what brand or type they use but would like to do it myself in the future and had planned on buying the Dyna beads but yours are less expensive and my hunch is they are the same product. I am somewhat apprehensive about switching just because mine work perfect but they charge $40 a tire.
I went from a swimming head to an exploding head on this project, Every time I think I have this by the tail, another specification or piece of information sets me back.
Here's the question of the day: The manager at the tire place tells me aftermarket wheels are not hubcentric, so they install plastic hub rings to make it so. My understanding was hubcentric on our diesels was more to put the load on the hub, rather than worrying about centering and balancing alone. Do our 8 lugs take the whole load, or should I focus more on the OEM hubcentric wheels?
edit: here's a link to the AL hub rings, they explain the difference between plastic and AL: https://www.uswheeladapters.com/hub-rings/
Checked ebay just now and there are no sets of 4 available in any style. There is a place that sells new ones for $369 each free shipping for 4. I guess I was lucky to find my set for $1,050 shipped, with center caps. Might have to watch CL and ebay for a while, I'd like to pick up one more for a spare since they seem to be getting more scarce. If I hadn't been lucky enough to get my set I probably would've got aftermarkets but with AL centric rings.
https://www.finishlinewheels.com/FOR...04/A-03551U85/
If it's really just a matter of centering for balance, I have found wheels with the 125mm hub bore - which is the OEM size. I also found hubs with 126mm hub bore, which is the worst thing one can get: 1mm is enough to let things get out of center, but not enough to fit a hub ring. A hub ring with a 0.5mm wall in plastic or aluminum won't hold up over time.
#28
Thousands run lug-centric and tow heavy with no issues. I'm one of those and can tell no difference from OEM wheels to after market with balance. The After market 18X9's do tow better, steer easier, and look better so I'm not worried about the hub centric. My thought is it's cheaper for OEM to make one "precise" (albeit not a true interference fit on the hub) hole than 8. With proper torque, the wheels stay on the truck fine.
#29
That's about what I figured, but I have learned better than to assume anything with Stinky. Since I do tow heavy in the mountains, I pay more attention to detail.
#30
Rich,
When I went to 18's I purchased some 2" hub centric spacers from an Amazon vendor. I did have to do some machining on them as the hub centric diameter that fit the wheel wasn't long enough to engage the wheel....in effect making them lug centric. And, if I had not machined the lip deeper (in essence making a 1 3/4" spacer) the wheel run-out would have been terrible....be sure you fit a hub-centric wheel or spacer.
IMO the clamping force of the lugs is what is carrying the weight.
