Oil Pressure Gague accuracy
Hi Everyone,
Whats your experience with the level of accuracy of the factory oil pressure gauge? My oil pressure has been low and I’m hoping it’s the gauge so I’ve been thinking about adding a aftermarket unit.
The OIil pressure starts at 40 and ends up just below 20 when the engine is warm and does not increase much with a change in RPM. I’m running 20-50 oil.
The engine is a 54 239 Y-Block.
Thanks,
Chris
Thanks,
Chris
What you could do is change oil and filter with a straight grade SAE 30W detergent oil (as a baseline), and with a mechanical gauge tee'd in the line with your sending unit and compare the two at cold and warm idle speeds. That will pretty much tell you what you want (or not want) to know. With this scenario you can also see what differences the multi-grade oil with additives is giving you. Save your used drained multi-grade oil for reuse. I do not recommend using any oil additive because in some cases they void the oil's original additive package.
Here is a viscosity comparison I made several years ago for another forum. Kinda unrelated, but you can observe how the different oils react to different temperatures.
I got a test oil pressure gauge and hooked it up today.
Unfortunately, my factory oil pressure gauge is pretty acurate. I’m running around 40psi at start up and fall down to 25psi when it’s warm. The PSI will probably go a little lower when the trucks actually moving/working.
I think I’m going to try to flush the motor with two quarts of oil and two quarts of ATF and then try to drop the pan and see if I can clean any sludge out. Any sense in messing with the oil pump while I have the pan off? After this... I’ll probably just run it till it blows up and then rebuild it.
Chris
Chris
I would save the expense of using ATF as it has no detergents and is basically ISO AW 32 hydraulic oil with "stiction" additives and red dye. If you want to go the added expense use a regular snake oil flush additive like Rislone, STP, or Ravenol. And I would do as Ray suggested first. Drop the pan (save the oil for flushing).
Good idea on dropping the pan first, I’ll do that.
i thought ATF was very high detergent? How about 50 percent oil and 50 percent diesel fuel for a flush? I don’t think I would run this mix for more than 10/15 minutes.
any reason to take a look at the oil pump?
thanks again for the help.
Chris
Chris
Before the days of ULS diesel that would have been ok at no more than a 15% dilution. But with today's diesel at ~50ppm sulfur it won't help much. A 50% dilution is asking for trouble. I would just use the snake oil. You can inspect the oil pump if you want, but I think you'll find there is nothing wrong with it.
Chris
Chris
This indicates that your oil pump is fine and still lifting the relief. When you drop the pan for the clean out you might consider PlastiGaging a few of the bearings.
