Ball park trailer GVW est - Ford Truck Enthusiasts Forums
Old 10-27-2018, 11:25 AM
Eric Fullerton's Avatar
Eric Fullerton
Eric Fullerton is offline
Eric Fullerton is starting off with a positive reputation.
I have an all metal 18' car hauler that I am going to use to move some round hay bales, and am trying to decide how many per load. Likely the bales will be in the 900 - 1200 lb range, the trailer has a data plat which give the GVW as 3500 front- 3500 rear, I assume that is cumulative, + 7000 lb, but that doesn't allow for the weight of the trailer itself, of which I have no idea. The puller will be a '96 long bed single cab 4.9 5 speed, the one way distance won't exceed 30 miles, for what that is worth. Just hoping some of the more knowledgeable folks will have at least an opinion.
Old 10-27-2018, 03:13 PM
Destroked 450's Avatar
Destroked 450
Destroked 450 is online now
Destroked 450 has a good reputation on FTE.Destroked 450 has a good reputation on FTE.Destroked 450 has a good reputation on FTE.
You won't be able to load on top of the fenders so 3-4 bales is all you'll be able to haul at one time depending on what size they are
Old 10-27-2018, 05:02 PM
Eric Fullerton
4 would be ideal, looking to move `12. I haven't seen them yet, but I believe they are 4 X 6. Should be able to haul 2 on the front deck, 1 between the fenders, and one hopefully forward of the dove tail. I don't wan a lot of tongue weight, but for 20 -30 miles, that should be doable. Even if they are the high estimate of 1200 lbs, that would total out 4800 lbs, and we have had trucks on it that weigh more than that.
Old 10-27-2018, 07:59 PM
Destroked 450
Although they say a 4x6 can weigh up to 1200 lbs a standard grass bale that size will be closer to 900-1000 lbs, my baler will make 4x6 bales but I have it set for the smaller 4x5 size, they average 7-800 lbs, if they are the larger 5x5 or 5x6 bales you'll only get 3 on at a time.
I haul 14 4x5 bales per load but I have a bigger trailer, I also bale over 1000 bales each year.
Old 10-27-2018, 10:10 PM
Eric Fullerton
It is Sudan, and in my experience they run a little heavier. I had one guy who baled Sudan up 5 X 6, & some of them made by backhoe (580) light in the rear carrying them on spikes on the front bucket. I dropped one down too quick, and stopped it way too quick at the bottom, and the rear did a little hop, I'm sure the rear wheels were off the ground.
Old 10-28-2018, 11:08 AM
Destroked 450
Yes Sudan grass is heavier, I baled some oats once, those bales were heavy.
Old 11-06-2018, 10:08 PM
eddienelson's Avatar
eddienelson
eddienelson is offline
eddienelson is starting off with a positive reputation.
1000 plus bales of hay? DAMN!!!
Old 11-06-2018, 10:28 PM
Eric Fullerton
Looks like I side stepped that for this year anyhow, the guy offered to deliver if I'd take a few more. Good thing, his were 5.5 X 6, and the heaviest bales I've ever had to deal with. The backhoe struggled with every single one. the first one off the trailer apparently bled all the air from the hydraulic system, it was a controlled fall as the bucket tilt rolled forward nearly dropping it, there was a a rush of air into the reservoir, after that it was ok-ish, still struggled to move them, but the slop was gone from the hydraulics. I rebuilt a couple of cylinders, and changed a few hoses, it seemed ok up til just then, but apparently there was some air in the system. Alls well that ends well, we have some happy cows!!
Old 11-07-2018, 10:02 AM
Destroked 450
Yea those 5.5x6 bales of Sudan can weigh over a ton, make sure you get the bale spike all of the way in on those bales, I snapped one off a few years ago moving some of those big bales.
Ran low on hay at the MIL's place and bought around 40 of those big bales to finish out, hauled them on a small trailer like yours three at a time, snapped the spear off trying to set the bale in the middle of the trailer from the rear.
Head gasket was leaking on the F-450 so I was hauling with the wife's Z71 1500 half ton, big trailer was to much for that truck.
The cost for gas making fourteen 35 mile round trips plus replacing the spike made for some pricey hay.
Old 11-07-2018, 07:06 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is online now
1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold
My car trailer scaled out around 1,700 pounds. Yes, a pair of 3,500 pound axles will give you a GVWR of 7,000 pounds. 4 bales at 1,200 pounds is a safe and reasonable assumption.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
