48 f1 brake booster - Ford Truck Enthusiasts Forums
48 f1 brake booster
Old 10-26-2018, 10:38 PM
Ffbrass's Avatar
Ffbrass
Ffbrass is offline
Ffbrass is starting off with a positive reputation.
48 f1 brake booster
Ive got a firewall mounted brake setup with a 7 single diaphragm booster. Im replacing my pedal and brake setup with the cpp pedal assembly and was wondering if I should upgrade my booster to a dual diaphragm booster or if anyone thinks the 7 single is fine.
Old 10-26-2018, 10:50 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
When you say you're replacing your 'brake setup' what does that mean, exactly? How do your brakes work now? Why are you changing things?
Old 10-27-2018, 01:52 PM
Ffbrass's Avatar
Ffbrass
Ffbrass is offline
I have a firewall mounted master cylinder and brake booster. The firewall is flexing like crazy so Im going to replace it with a peddle setup that is made for a 48-52 f1. Im also having a problem with soft spongie brakes due to the brake booster rod not being adjusted properly. I figured that since I was ordering the peddle assembly Id just order a new master cylinder and booster also. Western chassis is were I ordered all this from and they are suggesting a dual diaphragm booster. Im trying to figure out if I really need the dual diaphragm or not.
Old 10-27-2018, 05:15 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
When it comes to boosters, more is typically better. Here's a brief tutorial on the why's and wherefore's of power brakes from one of the leading aftermarket brake companies you may find helpful.
https://techtalk.mpbrakes.com/booste...ur-classic-car
Old 11-30-2018, 02:17 PM
4T9R
4T9R is offline
4T9R is starting off with a positive reputation.
Thanks for the info. I'm at the point of planning my systems. I am concerned about the firewall too. I bought some nice Wildwood brakes, not installed yet.
​​​​​​​my question is about a clutch pedal. Should both pedals be replaced? What have others done??
Old 12-01-2018, 03:39 AM
1949f1's Avatar
1949f1
1949f1 is online now
1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.
I added braces from the firewall to the bottom of the dash on my 49 and it doesn't flex any. Why not try this before you change everything?
Old 12-02-2018, 05:19 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
GreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to all
I used a 9 inch dual diaphragm booster for my 49 and was very happy with it.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
