7.3 leaking lots of oil - Ford Truck Enthusiasts Forums
Old 10-25-2018, 07:00 PM
'99F250's Avatar
'99F250
'99F250 is offline
'99F250 is gaining momentum as a positive member of FTE.'99F250 is gaining momentum as a positive member of FTE.
Well maybe not THAT much but it's still quite a bit. Went on a 400 mile round trip last weekend to haul a small tractor home, when I got home I found oil speckled all over the front of the trailer and my tailgate, as well as along the sides of the truck and of course the whole underside had oil on it. While it's great rustproofing I'd like to not have to add any oil to this thing. When I checked the oil level after I discovered the leak it was about halfway down the checkered mark, seems like quite a bit of oil for 400 miles. So now I gotta figure out where the heck it's coming from. I have a buddy with a hot water pressure washer, but he can't do it for another week, so until then I might as well ask the 7.3 experts on what it could be. The valley is relatively dry, I just did a turbo rebuild and EBPV delete, and the valley looks the exact same as when I left it. Also, the gap between oil pan and tranny looks drier than the bottom of the pan so I don't believe it's a rear main or valley leak. The whole oil pan is wet, from front to back, so I'm guessing it's up front. Checked the HPOP reservoir and from the top it looks clean and dry. The oil pan seal itself LOOKS to be the culprit, but that's a lotta oil to be coming from the pan gasket. Most places I look it's relatively dry above the pan gasket, and wet below it. Is there anything else that could cause this much of a leak? I want to get out and do more checking but currently it's raining and I haven't had a chance to look yet.
Old 10-25-2018, 07:04 PM
DavenTn's Avatar
DavenTn
DavenTn is offline
Fishslayer
DavenTn has much to be proud ofDavenTn has much to be proud ofDavenTn has much to be proud ofDavenTn has much to be proud ofDavenTn has much to be proud ofDavenTn has much to be proud ofDavenTn has much to be proud ofDavenTn has much to be proud ofDavenTn has much to be proud of
Oil cooler is my guess... can't see it from here.
Old 10-25-2018, 07:15 PM
'99F250's Avatar
'99F250
'99F250 is offline
That is one thing I don't think I checked, I will definitely look harder at that...
Old 10-25-2018, 08:47 PM
Walleye Hunter
Walleye Hunter is online now
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
How 'bout the dipstick where it enters the pan? That seems to be a fairly frequent problem.
Old 10-25-2018, 09:13 PM
'99F250's Avatar
'99F250
'99F250 is offline
It is leaking from there, but it doesn't look like it was gushing out
Old 10-25-2018, 10:28 PM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
. This would be my guess too. This is what mine looked like when it finally went...hemorrhaging oil!
The fix:
Old 10-25-2018, 10:37 PM
'99F250's Avatar
'99F250
'99F250 is offline
https://youtu.be/xM2wEXIohzM
The fix:
https://youtu.be/8qRyEmNo5jg
Good gosh that's a leak, maybe tomorrow if I find time I'll just sit under it while it's running and watch some more.
Old 10-25-2018, 10:41 PM
Colorado350
. LOL, I believe I said something different than good gosh but yeah it was a leak. I got very lucky in that I caught the leak literally in front of my house 5 minutes before leaving for a long weekend. But what you described is EXACTLY what I had, oil everywhere, coating everything Ö. Good luck!
Old 10-25-2018, 11:06 PM
'99F250's Avatar
'99F250
'99F250 is offline
No kidding you were lucky! You wouldn't have made it far with it flowing like that. Did you have to pull the pan off to fix it?
Is there an aftermarket setup that takes care of the dipstick leak? Seems to be a real common problem...
Old 10-25-2018, 11:16 PM
Colorado350
The engine needs to be pulled to remove the pan. So I used the repair kit from Strictly Diesel, ordered on Friday, received on Tuesday. Took 2 hours to fix, dropped starter and followed instructions. You will need a locking needle nose pliers.
https://www.strictlydiesel.com/p-269...epair-kit.aspx
Old 10-26-2018, 07:42 AM
Walleye Hunter
Here's a link to a current thread on the subject, there have been many over the years.
Dipstick oil leak
Old 10-28-2018, 09:23 AM
DavenTn's Avatar
DavenTn
DavenTn is offline
Fishslayer
Dipstick tube leaks are usually pretty obvious. I actually had a leaking dip stick tube and replaced the insert at the same time. That isn't the easiest job. The monkey and football comes to mind.
One thing I would recommend before taking anything apart on the oil pan regarding the dip stick insert.... make sure the internal parts are secure before you begin. The male threads on my original part were badly corroded and when I began to loosen the large nut, it just fell apart. In other words.... remove the dip stick tube insert first and secure the internal parts before trying to loosen anything.
Old 10-28-2018, 10:34 AM
Walleye Hunter
My understanding is that you DO NOT want something there to fall into the pan but I don't know what part it is.
Old 10-28-2018, 12:29 PM
Colorado350
Itís the o ring.
To get the o ring, Use a locking needle nose pliers to grip the flange through the opening for the dipstick put this on before even unscrewing the nut! Once the flange is secured unscrew the nut, gently push the flange in then use a pik to slowly remove the o ring and pull it out through the opening. FYI-It will be around the pliers. Either snip the o ring off or hang on to it then push the flange into the pan. Clean the outside of the pan to prepare for the new dipstick adapter.
Old 10-28-2018, 02:09 PM
Walleye Hunter
I was thinking more like the flange you don't want to loose but an O ring in there wouldn't help any either.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
