7.3 leaking lots of oil - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 11-07-2018, 10:47 PM
'99F250's Avatar
'99F250
'99F250 is offline
'99F250 is gaining momentum as a positive member of FTE.
Well it looks like I'm getting the nugget, I'll try to remember to post pics of everything installed.
  #32
Old 11-08-2018, 08:42 AM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
You’ll want a needle nose locking pliers to grab onto the flange while you use an angled pick to pull the oring off the flange.
  #33
Old 11-08-2018, 09:33 AM
Sous's Avatar
Sous
Sous is online now
SXE Junkie
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Originally Posted by Colorado350 View Post
Youíll want a needle nose locking pliers to grab onto the flange while you use an angled pick to pull the oring off the flange.
Needle nose vice grips like in the picture below, or something different?
  #34
Old 11-08-2018, 12:21 PM
Colorado350
Yes, the nose needs to be small enough fit into the dipstick hole to hold it in place while you pull the oring out from inside the pan. The locking part makes sure you donít drop it before you get the oring.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
