Disc Brakes
Old Oct 25, 2018 | 10:07 AM
dobenator's Avatar
dobenator
Disc Brakes
Im thinking about putting disc brakes on my 53 f-100. I thought I saw a post here where the master cylinder was installed under the cab where the original one is. Is that possible and could I use the same brake pedal set up? Thanks for any info. This place rocks!
Old Oct 25, 2018 | 10:22 AM
Dangeruss's Avatar
Dangeruss
Yes it is possible and actually pretty easy to do. I installed mine in a day. I bought my kit from Mid Fifties and it had everything I needed to make the conversion. The only thing I wish I would have done is spent the extra money to switch the rear over to discs as well. Live and learn I guess.
Old Oct 26, 2018 | 07:31 AM
petemcl's Avatar
petemcl
Yes, you can do that but buy the right kit, disc/drum or disc/disc so you get the right residual check valve. Also you will want to install a remote fill.
The firewall mounted option is not bad either as they make pedal sleds with all the pedals mounted hanging which make carpet installation easier and cleaner. Also no remote fill is needed.
Old Dec 29, 2018 | 10:45 AM
Cobravii's Avatar
Cobravii
I'm in the process of building my '50 F47 and this is what I have so far....
Old Dec 29, 2018 | 10:54 AM
Cobravii's Avatar
Cobravii
Doesn't look like it will let me attach the pics.....
here's a link to my facebook album, you will have to scroll down to find the brake conversion pics...
https://www.facebook.com/larry.loren...5495213&type=3
Old Dec 29, 2018 | 11:29 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Here is a picture of an F100 with power brakes, from the bottom. I looked around a little, but didn't find one from the top.
The angle iron across the bottom of the frame is the rear transmission mount. It has nothing to do with the brake MC or booster mounting.
This uses the factory brake pedal. It would need the remote filler/reservoir, as it puts the MC below the seat area of the cab. Otherwise you have to crawl under the truck and use some kind of squeeze bottle for filling/topping off the MC.
Old Dec 30, 2018 | 10:51 AM
Indybeer's Avatar
Indybeer
I don't have any pics of it... but I cut a hole in the floor above the master Cylinder and made a cover plate for it instead of mounting a remote reservoir. I'm not putting carpet in just the mat and will make sure I can access it if needed.
danno1965
13
Mar 17, 2020 10:38 PM
filthy6
Nov 30, 2015 03:44 PM
Dskeet6
Apr 14, 2015 08:35 PM
jerryst
Oct 5, 2011 10:29 PM
Roy in TX
41
Mar 26, 2005 07:26 PM
