Onboard Air
Onboard Air
Hi, I have a 2013 Ford F-150 fx2 super crew, short bed 5.0 and I want to install a bigger air tank than what I have now currently in the front bumper. I was thinking to install it on the outside side of the frame under the cab. I don’t know what size tank as in dimensions. If anyone has installed one in the area I’m think about, please share, would be appreciated. Thank you.
"Smaller" and " Bigger" is relative
You say bigger . . . don't know what you have now? if you could say the size of your current tank in gallons and physical dimensions (length X diameter).
A pic of your current installation would be helpful even to those thinking of installing their own.
Currently I have a 3 gallon that will fit between the frame rails between radiator and bumper not blocking airflow, just gotta make brackets(winter project)
TMyhre
06-02-2015 09:06 PM
fifty-two_f1
25
01-18-2011 11:05 AM
