7.3 idi 5 speed into a 95 powerstroke?
Hey guys, so i recently picked up a 95 f250 powerstroke 5 speed when the engine in my f150 gave up. My only problem is that it is 2wd and I would like to have 4x4 for winter. I found an older f250 7.3 idi parts truck for sale with a 5 speed and 4x4. What im wondering is could I take the front axle and 5 speed out of the idi and drop them into my truck? Is the bellhousing pattern the same? Does the front axle bolt in or is modification required? Thanks in advance guys.
Received 3,090 Likes
on
That's a massive waste of plywood.
I could probably get by with just 2wd in the winter, but being in Canada winter can get pretty nasty. If I knew what was wrong with the truck then getting it to run would be a possibility. However I don't know a whole lot about diesel engines(this is my first diesel truck). I could get my f150 running again for winter, I just thought it would be nice to run my powerstroke instead as it is far better on fuel.
There is a dedicated idi diesel forum here with lots of good information and lots of helpful people.
Didn't hurt the plywood. Just doing what we could do with what we had to work with. People used to think like that in the olden days when they didn't live life on mama's couch with Internet, TV, legalized marijuana, opioids and video games.
on
2 wheel drive is coil spring, 4 wheel is leaf spring. so all the front mounts would have to be made. a 05 and newer axle swap would ne a little easier since they are coil sprung, but it is still not a bolt in deal. cab and bed swap is by far much easier than converting a 2 wheel drive to four wheel drive.
Says the guy who'd rather leave a bunch of plywood out in the weather all winter than shovel dirt into the back of his truck
on
As others mentioned, your truck using coil springs and the 4x4 using leaf springs complicates the swap. I disagree about it being easier to swap everything to the 4x4 chassis. Swapping an entire cab, bed, 7.3 PSD, and then reconnecting all the wiring, etc... is a huge undertaking. Welding some leaf spring mounts in the proper spots would be easier. However the main reason you wouldn't want to do the swap is that the F-250 4x4 has the TTB front axle. It's not a great axle, and has a lot of complexity that would make the swap more difficult. You'd be better off finding an F-350 4x4 to get parts from.
My advice is to get a set of crappy 16" steel wheels, and put Nokian Hakkapeliita R3 SUV tires on them for the winter. Put ~500 pounds of sand bags in the back of the truck, and you won't even notice you don't have 4x4. Proper winter tires make a HUGE difference. Proper winter tires even put all-terrain and mud-tires to absolute shame in the snow.
50 pound bags of sand cost about $1/each from Home Depot. They're heavier and far cheaper than a piece of plywood. Just leave the sand in the bags and it makes for easy cleanup in the spring.
on
How is everything you listed a "single day" worth of work, but hacking out a suspension is "3 days"? We've built completely custom front/rear suspensions for Jeeps in a single evening... Not to mention what you're proposing is basically impossible without a lift, overhead hoist, or at least 4-5 very strong people willing to help you.
on
wildstang
11-13-2018 09:14 AM
BSnow54
06-01-2017 08:46 PM
