99 5.4 4X4 4r100 no drive after pump replacement
I picked this truck up for cheap. A previous owner managed to break off the input shaft to the transmission while replacing the engine. He sold it to someone that put a new pump in it.
The truck did move with the snapped shaft but nothing with a "remanufactured" pump from Ebay. I bought it from that guy.
I have a few suspects to check out. I'm going to drop the pan 1st and see if the filter fell off or something obvious like that. I'm also going to verify it's the right pump. Any other ideas? If worse comes to worse I'd love to throw a manual in it.
I have a pressure gauge on the way from Amazon
I'm thinking even if the new pump was weak or if an O ring got knicked it would still try and do something?
The engine idles up when you put it in a gear but nothing else happens. Even with the truck on jack stands.
Thanks in advance. I've never messed with one of these transmissions.
Poppa Squirrel
03-02-2015 01:43 PM
59INA40
11-27-2005 04:37 PM
72ford360
11-05-2004 04:28 PM
L-N-OR
09-05-2004 09:45 PM
