auto-crossing a 79 Ranger?
Was just wondering if I have any fellow lunatics who want to or have already built this generation of truck with high power and street handling in mind. I dont plan on actually crosing mine, but will be on the streets thrashing from time to time, and was wondering what solutions people had for suspension and steering. Been planning on a 416-418 ci LS3 and ~18 pinds of boost, with either a 5 or 6 speed manual. Open to ideas!
A Crown Vic frame and suspension swap would probably be the most cost effective. Rack and Pinion steering, bigger brakes, and independent rear suspension.
Not sure why you would put the LS in it though. A similarly boosted 5.0 coyote will make a ton of HP. Being that the Crown Vics came with a mod motor the Coyote might be a direct bolt in too.
Jess
Jess
Velocity's "Speed is the New Black" built a '70 autocrosser.
How? They dropped the cab, doghouse, and lightened bed on a The Roadster Shop frame.... 9-inch rear, IFS front end.
1967-72 Ford F100 Truck FAST TRACK chassis - Roadster Shop Roadster Shop
Pony up!!!
Pony up!!!
you can autocross anything...my truck drives in parking lots all the time.
if you want to be competitive you need a different platform.
If you don't already realize this, then you should only plan to do it for fun.
High power rwd vehicles with poor wt bias are never good in tight turns.
If you want a dyno queen then the truck would be just fine.
I have autocrossed a truck before. The lower you make it the better and you'll need some sort of locker or spool. I had a posi and it still didn't work all that well but when I went to a spool it was a lot better. You will not be competitive but you sure will have a blast abusing your tires!
Heres an idea: Leave the plastic and aluminum electronics and sensor infested LS/Coyote etc "swaps" out of the equation, and build a super reliable, easy to maintain torque monster MANLY, big boy engine, like a 351C with quench chamber heads, solid boss-spec cam or roller, mechanical FI or tunnel ram, connected to a toploader 4 speed. Build a stroked big block 429 SCJ/460 and go eat LS and coyotes for lunch for half the money, no special fab work and dollars-less maintenance.
on
Dentsides are the least likely generation of vehicle on the planet that needs an engine transplant outside the list of factory options. I drive all sorts of interesting vehicles every week. Very seldom do I get the pleasure of driving a 300/351/390/429/460 powered anything. Driving an ls3 camaro around (or a coyote 5.0 Mustang) usually isn’t the highlight of my day. Thats my opinion, but it just isn’t necessary to waste time on this.
After the IRS, those further mods would have significantly diminishing returns.
If I could auto cross in a early 70's Fiat 850 Spider that lacked reverse, you can do it in anything. It's not always about beating the Minis and Miatas but about being consistent and clean. Watched a big block 'Vette blow most every turn and completely miss the final turn due to too much right foot and too little skill. Didn't look like it was as much fun as I had in a 45HP car.
Michael
Michael
Originally Posted by hail destroyer
This is how we learned to "drift" insanely overpowered, jacked up and nose heavy muscle cars in the 80's LONG before punks like Ken Block were even born. The only way to live to tell about approaching an apex and an oak tree at a buck twenty in a poor handling high horsepower rig is to turn into it, and get the back tires smoking, then countersteer as required......or die. Maybe not the safest way through a turn, but definitely...the MOST fun.
(I mean no disrespect just joking around!)
Anyway to each their own, if someone wants to keep a dent side alive I'd rather see them driving it, enjoying it, and getting other people interested in a dent side instead of it going to the scrap yard.
Edit* I had to look up auto cross as I haven't heard that before now I know lol go race it and enjoy!
