Sponsored by: Halo Lifts
Rancho QuickLift fittment problems
Old 10-22-2018, 12:21 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I purchased a set of Rancho QuickLifts but after spending all that time to get them in, turns out one of them doesn't fit. The lower strut bolts don't line up. Am I missing something? I tried every orientation possible including switching sides.
Old 10-22-2018, 03:05 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
My understanding on coil-over setup's...is that you may need to rotate or clock over the lower mounting area to lineup...using large channel lock pliers, etc. With some videos on the Utube that I've watched...they say to make sure lower mounting lines up...if NOT, then you can to rotate and line them up.
Good luck with it!!
biz
Old 10-22-2018, 03:50 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I thought about that, but I couldn't get it to budge at all. I'll maybe try it again.
Old 10-22-2018, 04:03 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
The bad, is that you might have to use a spring compressor tool (to keep spring from expanding), and loosen the top nut...to help make the rotating a little bit easier.
biz
Old 10-24-2018, 08:19 PM
jthorngate3's Avatar
jthorngate3
jthorngate3 is offline
I ran into that with my eibach kit as well. I remember reading that you could twist them with channel lock pliers as well, but like you there was no chance of budging them. I also found that the bolts supplied were barely long enough to engage the nylock washer in the nut.
Old 10-27-2018, 01:55 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Were you able to fix it?
Old 10-27-2018, 01:58 PM
jthorngate3
I loosened the top nut just enough that it was still solidly engaged, and I spun the lower portion around with my pipe wrench. Didn't seem to cause any problems, though I wasn't too thrilled with doing it.
Old 10-27-2018, 10:53 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Yeah I'm not crazy about that either.
Old 10-28-2018, 06:33 AM
jthorngate3
On the eibach kit, I had to remove the factory top hat and lower spring mount to put on the new strut. That was a bit sketchy with the harbor freight spring compressor. I wasn't about to undo it and start all over again. If I remember correctly, I used the spring compressor to take some pressure off the top hat to spin the lower portion around. I marked everything to avoid having to do this, but I must have messed it up somehow. The passenger side went on no problem.
Old 12-14-2018, 12:40 PM
triniexr's Avatar
triniexr
triniexr is offline
How do you like the Rancho's? I am thinking of going this route but can't find much information/reviews on them.
Old 12-14-2018, 10:16 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I could not get them installed due to a fitment issue. I returned them and went with Bilstein 5100s
Old 12-16-2018, 02:42 PM
triniexr's Avatar
triniexr
triniexr is offline
How are those then? Are they better than just doing the spacer lift? Hows the ride? Were they expensive?
Old 12-16-2018, 02:44 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I have no complaints. They offer a better ride than stock, IMO. They ride firm, but not stiff. They were cheaper than the Rancho system.
Old 12-16-2018, 05:04 PM
jthorngate3
The eibach kit is very similar and similarly priced to the bilsteins. I went that route myself and have a similar review. Better ride, firm but not stiff. Functions well offroad as well.
Old 12-16-2018, 05:07 PM
triniexr's Avatar
triniexr
triniexr is offline
Can you guys give me the part numbers? Do you all do front and rear? I need to tow a dump trailer so I need to maintain a bit of a rake
Quick Reply: Rancho QuickLift fittment problems
