Drops dead on acceleration when cold - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 11-14-2018, 10:04 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
vjsimone is gaining momentum as a positive member of FTE.vjsimone is gaining momentum as a positive member of FTE.
Originally Posted by fordbozo View Post
The IAC seems to be ok?
Well the voltage & resistance look good, but is the valve opening and closing properly, tough to know.
Is the EECM sending signals to it, tougher to measure as previously discussed.
But, you can unplug the IAC to see if it make a difference.
  #47
Old 11-14-2018, 10:10 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
The smog pump is long gone. Any way to trick the box into thinking it’s working ok?
The 81 & 82 can be checked out, see post #33.
The 44 you may have to live with, not an issue.
If the TAD & TAB Solenoids are missing or if they are faulty, you can put a 100 Ohm resistor across the 2 pins in the connectors.
  #48
Old 11-14-2018, 10:17 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
21 cooling temp - I'm low on water due to a leak, I'll fill the radiator up.
You will need to recheck your Codes, a 21 Code, if valid, will give you issues....
  #49
Old 11-14-2018, 10:21 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
Take a close look at the TAB and TAD solenoids, if the thermactors have been removed, you need to verify that the vacuum lines are properly capped and plugged.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
