1994 F700 vin and axle decode - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Reload this Page >
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 11-08-2018, 06:30 PM
CJWisinski
CJWisinski is offline
CJWisinski is starting off with a positive reputation.
Originally Posted by Destroked 450 View Post
Keep in mind that most 4x4 conversions used single speed rear axles to keep the ratios the same, if you install a 6.50 ratio front you can not use the 9.07 low range while in 4x4.
If you do things will get real ugly, busted diff gears, blown drive shafts, broken transfer cases.
Absolutely. The guy with the axle doesnt know the ratio and finding it out ‘by hand’ is not super scientific. How close would the ratio need to be? Say I know mine to be 6.50 and I ‘calculate’ the other ratio to be 6.30 or something, how far could they be apart? Of course assume I will not be climbing rocks, the truck would be only in 4x4 for mud or ice/snow
Old 11-08-2018, 06:48 PM
85e150six4mtod
85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
6.50 and 6.30 would be about the max, for mud and slippery situations at low speeds. In pickups as OEM, they keep the differences in the 100ths, not the 10ths. (4.09/4.10, 3.55/3.50 for example)
Old 11-09-2018, 02:29 PM
Destroked 450's Avatar
Destroked 450
Destroked 450 is offline
Destroked 450 has a good reputation on FTE.Destroked 450 has a good reputation on FTE.Destroked 450 has a good reputation on FTE.
With 6.50's and 6.30's in mud and snow you'd get by, as soon as it got on hard surface things would bind up.
Kinda defeats the use of driving in 4x4 on partially snow covered roads.
As said ratio's need to be close.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
