Buying a truck with a bad engine?
Hello everybody!
I've searched this forum and other but can't find something to relate to my question.
I'm looking at a 1999 F350 extended cab with a V10, 5-speed, 4x4 flatbed with dump & DRW. From my searching it should have the dana 60 rather than the dana 50. I plan to check it out this weekend to get a better idea on it's condition. It was used as a tree service company till the engine went bad, current owner said his shop say's it needs replacing & would cost $3500.
He has it priced at $2500, so my question to you guy's is it worth buying to have a re-manufactured engine installed? I have plans to move to Montana in a few years and I know I'll need a solid truck when i get there. All the parts seem right & I think the truck should fit my needs.
I don't have any skill to do the work myself so paying a shop will be part of the total cost.
Last edited by Dirt Wagon; 10-20-2018 at 10:32 PM. Reason: typo - cabe changed to cab
The only benefit I see going that route is you’d have a new engine. I’d go look at the truck then get several quotes on replacing the engine. Is the shop owner capable of doing the work? If yes, maybe work a deal out with him. If No…where’d he get $3500 from?? The other concern I’d have with that kind of vehicle is that typically employees don’t take care of the equipment they use, it’s not their dime if they break it. If you stick $4K into the engine then the transmission goes out that’s another 4K...just something to consider
For the price of the truck and having an engine installed you can find a truck that age that is in good shape that already runs. I wouldn't buy a truck that was used as a work truck like that either. No telling what else on it is one step away from being worn out or breaking. Save your money and get something you can actually test drive.
Thanks for all your input guys!
I think I may have been building up the idea of buying it since it has the dana 60 under it along with the flatbed & manual transmission, the dump seemed like a bonus Seemed like a good base to build a truck off of. The truck is supposed to have only 150k miles on it but being a company truck has made me hesitant on how much abuse it's had.
I suppose if I were to spend another 6k to have a new engine installed it does add the cost of the truck up a good bit. Most likely why it hasn't sold yet. He did say it's somewhat able to drive but the engine is going out. Kinda made me wonder if it's actually as bad as the guy's mechanic said it was. I'll give the guy a call tomorrow and see if I can get some more information about it.
I was out of town but since I'm back home I can see if it's worth it or not. Last thing I want is a money pit, I have a second son on the way and main reason for buying it is to have the extra seating I for the growing family.
Not sure if these pic's will upload since i'm a new member, but thought i'd post them for ya'll to see.
on
The only thing I'll add to this discussion is the fact that Ford has a Factory Remanufactured Engine program that comes with a warranty that will be honored by any Ford dealership anywhere in the US or Canada. Your local Ford dealer can give you a price on their installing it for you, and you will know that you will be able to get it warranted easily in MT when you move there, if you need to.
https://parts.ford.com/shop/en/us/reman-gas-engines
I thought about just waiting to buy when I move NW but worry about any rust damage from the winter roads on older trucks.
Forgot to mention that the tires on the truck are fairly new BFG TKO All Terrains, so that's one less thing needed on it.
First off thats not even a DRW truck. It's an SRW that someone added duals to. How did they do it? Complete rear axle swap? I doubt duals would clear the springs with the stock pickup axle. If the rear axle was swapped does it have the same gears as the front? If it started as an SRW truck it would have the D50 front also. As opposed to factory D60 dually that someone removed the spacers from. Looks like a basket case to me.
