Spare Tire Carrier Part Help - Ford Truck Enthusiasts Forums
Old 10-20-2018, 12:36 PM
johnmel59
johnmel59 is offline
johnmel59 is starting off with a positive reputation.
Hi FTE,
I've been away from my 1965 F100 Flareside project for a while due to work but I ready to reengage again!
I need help with a two things -
  • first- I'm looking for the spare tire wheel carrier floor to sill reinforcement plate - part # C1TB-1413-A,
  • second - I'm looking for a "bolt up" pattern for the mounting of the spare tire carrier rack. I'm not comfortable just "eyeing" the correct placement and drilling the holes only to find I've drilled the wrong locations.
I'd happily exchange a few "dead presidents" If you have a pattern or would be willing to make me a pattern for the short wheel base (114"-115") truck.
Thanks in advance! John
File Type: pdf
Old 10-20-2018, 01:04 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C1TB-1413-A is 13 1/8" long = 1961/79 F100 Flareside with 6 1/2' bed / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
Shown in the upper pic:
Old 10-20-2018, 01:23 PM
johnmel59
Thanks ND,
can you search your massive contacts and see if anyone has one available?
John
Old 10-20-2018, 01:32 PM
NumberDummy
What it says...
Old 10-20-2018, 01:35 PM
johnmel59
thanks so much!
Old 10-21-2018, 09:16 AM
Bert65
Bert65 is online now
Bert65 is starting off with a positive reputation.
Since you are drilling out new,here is the bolt pattern for the top 4 holes.
Once you do these, then the bottom holes will fall into place, assuming the carrier is not bent
these measurements are from the back of the stake pocket towards back of bed and the top crease of the bedside panel (right where it starts to angle)
Mark 2 parallel lines from top crease 1" and 1 3/4"
top line the holes are at 6" and 18"
bottom line the holes are 3 1/2 and 15 1/2
1. 1 3/4" down x 3 1/2 out
2. 1 " down x 6" out
3. 1 3/4 down x 15 1/2 out
4. 1 " down x 18" out
BTW, I am looking for the bottom angle piece as well, so I will have to make it out of angle stock if I dont find one
Old 10-21-2018, 01:23 PM
johnmel59
Thanks Bert!
I have the top reinforcement plate part #1407, should I align the first bolt hole with the 6" top line mark? If so, the remaining top bolt holes are then set by those in the reinforcement plate.
I assume I'm too will have to fabricate the bottom reinforcement plate once I establish the correct bottom hole locations.
Old 10-22-2018, 05:20 AM
Bert65
yes the top hole would be the 6"
The diagram of 1407 shows each set of holes in the 10 oclock to 5 oclock position, but mine are in the 2 oclock to 7 oclock position
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
