Cheap DIY way to reduce lag
#31
#32
Just yankin your crank.
Pretty cool how something so cheap & easy can make such a huge difference. I'd previously considered the 10k, but don't like the idea of always having higher pressures working things harder, and some people report drivability and MPG issues with it. This doesn't seem to increase power or alter stuff much, just gives a momentary power boost to get past the lag which I think should be very safe. I recommend putting an inline fuel filter in to reduce the chance of soot getting to the MAP sensor and maybe messing it up. It might have to be something stronger than the average cheapo clear plastic ones to handle the pressure.
Would also be nice to know what the computer will do with seeing no EBP. May be worth putting a T in the line to connect the EBP sensor. I assume if one still has the EBPV it might be more important to have that sensor working, but I don't know.
#33
#34
#36
#38
#39
#41
#42
Got imploded with the holiday season kicking in. Customers starting earlier every year. Wasnt able to do that run but have managed to rack 37x miles. Filling up this morning for docs purposes here. I DID switch back to stock form due to fear of a hose meltdown, Until i can figure out a more permanent solution(AN fittings/brake lines)..i was in the motor for gp replacements
#43
#44
have you tried adding some of the archoil additive to oil and fuel for the sticking injector(s)?. The 6.0 guys swear by it. you can get it of course on amazon and read the reviews.
I don't keep track of MPG so unless something big happens I won't know about it. I only checked it once on a road trip playing with a tuner.
I have cold sticking injectors and this mod has helped greatly. When one is stuck the acceleration is really bad, at WOT it takes almost a block to get up to 2kish RPM where it'll suddenly unstick and go. Pretty sure it's when the computer commands the longer injection that it finally pulls the injector free. When two are stuck I could be outrun by a 90 year old using a walker. After the mod: with one stuck I can now accelerate about as well as stock with none stuck and the one that is stuck will unstick much more quickly. The less sticky one will now free up as soon as I press the pedal in Drive, even a god rev in P will do it.
#45
have you tried adding some of the archoil additive to oil and fuel for the sticking injector(s)?. The 6.0 guys swear by it. you can get it of course on amazon and read the reviews. https://www.amazon.com/s/ref=nb_sb_s...=1DBJ19LVWAMWL
