late-model 4cyl in an old econoline? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-18-2018, 07:03 PM
vanagone's Avatar
vanagone
vanagone is offline
vanagone is starting off with a positive reputation.
would it be possible to put a late model 4 cylinder (like an ecoboost 1.6 or 2.0) into a 69 econoline 200? iím not interested in going particularly fast, just looking to find a more efficient option for my hippie van.
Old 10-18-2018, 11:38 PM
85e150six4mtod
85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Welcome to FTE.
Sure, you can do that. You might save some gas, but it would be hard to save money doing it.
You have a shop, welder, donor car?
And:
https://www.scs-delta.co.uk/ford-ecoboost-ecu
Old 10-19-2018, 07:10 AM
00t444e's Avatar
00t444e
00t444e is online now
00t444e is gaining momentum as a positive member of FTE.00t444e is gaining momentum as a positive member of FTE.
A better option would be a 4bt Cummins. Its cheaper, easier to swap since its all mechanical and only takes 2 wires to make it run, easy to find parts for, and it will have plenty of torque to pull that van and can achieve 25 MPG or higher depending on the weight of the van.
Old 10-19-2018, 09:55 AM
jeffreyclay's Avatar
jeffreyclay
jeffreyclay is offline
jeffreyclay is starting off with a positive reputation.
If someone was going to the diesel route, what are the guidelines for transmissions and rear end ratios since the high limit for a diesel is around 2500 RPM?
Old 10-19-2018, 10:22 AM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
Rearend ratios for diesels are the same as gas engines. My 99 SD F250's rear is 3.73. And speakin of 4 bangers, I drove a Dodge Ram van last year to Kansas, coulda sworn it had a hemi in it. It wasn't. It was a big 4 banger that if doubled added up to a 500+ inch V8. And got 17 mpg on the highway doin 75 . If it weren't so butt ugly, I'd a thought about buyin one.
Old 10-19-2018, 10:28 AM
00t444e's Avatar
00t444e
A Diesel is better off with a higher geared rear like 3.55 or 3.73 and an overdrive transmission since the operate at a lower rpm. What transmission and gear ratio do you have now?
Old 10-19-2018, 03:01 PM
85e150six4mtod
An E200 is either going to be a Ford 303 3 on the tree, or a C4 automatic.
Axle ratio would be 3.50 or higher numerically, even a 4.10 would be possible.
Even with a balance shaft, aren't those motors a real shaker? Especially when it's at your elbow?
Old 10-19-2018, 03:26 PM
00t444e's Avatar
00t444e
Originally Posted by 85e150six4mtod View Post
An E200 is either going to be a Ford 303 3 on the tree, or a C4 automatic. The old 4BT and 6BT Cummins are pretty smooth running, they only shake allot on shutdown.
If you are running a C4 I would recommend 3.07 gears and a low stall converter if you are going to use a diesel engine. The old Cummins 4bt and 6bt are pretty smooth running, they only shake allot on shutdown.
Old 10-19-2018, 11:09 PM
baddad457
A C4 will NEVER hold up to a Diesel. The HD C4 didn't hold up to a 302. I had a 69 Club Wagon for ten years and had the C4 rebuilt 5 times. Every two years you could bank on it takin a dump.
Old 10-19-2018, 11:11 PM
00t444e's Avatar
00t444e
I agree that it's not the best choice for a diesel but they can be built to handle quite a bit.
Old 10-19-2018, 11:47 PM
85e150six4mtod
This is one of the problems with that conversion. OP is pretty much stuck with an automatic due to the "way back" placement of the transmission in that model van.
Old 10-19-2018, 11:56 PM
00t444e's Avatar
00t444e
A good built E4OD/4R100 transmission with a stand alone PCS controller would probably be the best option but not cheap.
Old 10-20-2018, 12:18 AM
baddad457
He'd do better with a C6. The stuff done to C4's are geared towards drag race applications, not everyday use. The C6's were used behind the 7.3's
Old 10-20-2018, 12:23 AM
85e150six4mtod
After an extensive 45 second search and review, it seems the 4BT came with a GM TH400 in a lot of Chev chassis trucks. In Fords, he says, mostly manual transmissions.
So, a 4BT to GM auto would be easy, but OP would probably have to step up to a later, stronger, electronically controlled transmission.
And then there is Dodge. A 47RH/RE from behind a 6BT in a Dodge pickup would work.
Nowhere do I find the words "cheap", "easy", "inexpensive", or anything else leading me to believe that the OP would be well served going down any of these roads.
Old 10-20-2018, 12:27 AM
85e150six4mtod
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
