Hot Water Valve - Elbow - Ford Truck Enthusiasts Forums
Old 10-16-2018, 02:05 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Rusty_S is a name known to allRusty_S is a name known to allRusty_S is a name known to allRusty_S is a name known to allRusty_S is a name known to allRusty_S is a name known to all
Im looking at my diagrams and noticed the hot water valve in the intake manifold mounts into a 45* elbow. part number 353476-5100 II-173 says its a 3/8-18 elbow. Cant find this part and wanted to know is this part needed? Mine the valve is threaded straight into the intake manifold. Not sure if the elbow is needed or if all vehicles even had the elbow from the factory.
Old 10-17-2018, 07:45 PM
Boundertom
Boundertom is offline
Boundertom is starting off with a positive reputation.
3/8-18 is a standard pipe thread size. Fittings should be available at any well stocked hardware store. You will likely find them in black iron, galvanized, and brass. I am almost certain that this elbow is not required, except possibly for a neater or more efficient routing of the hose. If everything fits without the elbow, I would say don't worry about it.
Tom, in AZ
Old 10-17-2018, 08:03 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Tom, in AZ
Ah ok. I know about that I found some but what has me concerned is the new hot water valve has a brass insert it said to remove short insert for I6 use. I just don't see how that 3" looking insert would fit a 45* elbow that's why I was wondering. Currently its threaded into the engine straight but when I replace it I would like to put the correct pieces on as best as I can.
Old 11-04-2018, 03:04 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
KULTULZ has a very good reputation on FTE.KULTULZ has a very good reputation on FTE.KULTULZ has a very good reputation on FTE.
Post
The fitting you are describing was only used on certain models/engines to allow the HEATER VALVE to clear the ACL. Your application doesn't use it.
Here is a photo of a '55 272 setup that uses one
Old 11-09-2018, 10:28 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
See that's the thing. It shows the same elbow listed for '56 Ford fresh air heater diagrams as well.
Old 11-10-2018, 03:35 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
At times the MPC TEXT and ILL can be confusing.
That's why it is nice to have Bill and Jeff here.
Old 11-10-2018, 02:44 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
yep thats why i am curious. I got a brass 45 degree fitting but when i put my original 56 intake back on i want to be sure if it had the 45 or not as my goal is to have the car correct as it was built by ford.
Old 11-10-2018, 08:11 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
As long as your 56 is a 292/312 H4000 4V with the correct year ACL, you do not need the fitting.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
