Tune up difficulties?
I've yet to fire up my rebuilt 292 and my previous owned early 60's Fords did not involve Y-blocks. So, with winter approaching again, I decided to pull the plugs and make sure the cylinder walls were well oiled. I never gave it much thought how hard it is to R&R the plugs with the exhaust manifolds in place. I didn't even have the front clip on when I installed the plugs, as well as the dual exhaust manifolds. I ended up crawling under the truck to do the job, it just seemed to be much easier. Is that what you other Y-block owners are used to doing?
Wrong? I can’t imagine what, unless it user trouble, lol. Maybe if I was taller, I could reach over the side and underneath the manifold easier. Of course, you can’t see the spark plug holes hiding under there. The heat shields do seem to interfere a bit more than they should. I bought a repop manifold set, so maybe has less exterior clearance in some area. I form fit the heat shields with a hammer to allow the spark plug socket avoid binding. The other thing I jury rigged was the dipstick tube when I changed to dual exhaust. I just made my own bend, so maybe it’s not in exactly the right spot.
Rams horns don't hinder plug access. If you are shorter, that could definitely complicate the task but that's hardly a problem with the engine or truck. I'm also not sure that the heat shields were meant for use with the rams horns so that might be an issue - that you had to modify them is a clue there. Your customized dipstick tube could also cause problems with access to some plugs on the passenger's side.
They're all pretty much a straight shot with oem style manifiolds, super easy to get to.
Rams Horn manifolds used a different kind of heat shield, that protects the valve covers. I haven't found spark plug access particularly bad. Maybe plugs 3 & 4 are kind of a pain. I start with the plugs at the rear and finish up with the easy ones. #5 being a sweetheart. I envy the 6 cylinder folks sometimes. Now there's a well thought out design. Fuel pump, distributor, coil, plugs etc etc, easy to get to, plenty of room.
Well, I'm 5'8" so I don't think that's your problem.
I don't think I had heat shields when I had rams horns. At some point, I did have a set of metal gaskets, I think from Napa, that did have a heat shield for the valve cover but I don't remember if it incorporated the plug wire heat shield. I think that I only had those at some point with the single exhaust manifolds.
flipklos
01-31-2009 07:23 PM
