no 4 low?? 78 f100
no 4 low?? 78 f100
ever since i got the truck i have been unable to shift into 4 low. it doesnt grind. it works fine in high. the shift lever is very simple and only goes in and out. does not have a nuetral either. no metal shavings and i have flushed and replaced the oil. it barely even leaks. the np205 as i understand has two locations to activate 4wd. one for actual 4wd and the other for low and high range. someone educate me if you would.
corksil
04-23-2015 08:06 PM
deanzawistowski
13
12-11-2007 06:16 PM
