2001 shutters or hard shifs in and out of overdrive?
Back in January I bought a 2001 Ford F150 xlt with the 4.2l v6 and automatic transmission with around 157,000 miles. When I first got it I changed ALL the fluids including the transmission and filter. I could tell this was the first time the transmission fluid had been changed because after watching a youtube video they said if a yellow plastic piece was in the pan it was something that is used at the factory and that would indicate that the fluid had never been changed before. I found the yellow plastic piece in my pan when I changed the fluid. The truck (since I bought it) when shifting in and out of overdrive has always had what feels like to me as a shuttering or a hard shift. The shift isn't super hard, but to me it feels like it kind of shakes the truck. All of the other gears shift just fine. I added a bottle of the lucas oil a few months back for transmissions with shifting problem, but it did not help. It has never failed to shift in and out of overdrive.
Just wondering if it is going to eventually leave me on the side of the road one day .
Any comments, advice, or input would be greatly appreciated.
Thanks,
brc
Thanks,
brc
I did change the spark plugs. I know that in one of my Mom's cars we swore up and down it was the transmission. Had to take it to the dealer and it was a cracked spark plug. So that was one reason I changed the plugs.
I have not had the transmission checked for codes or check the u joints. There are no lights on.
How do you scan the transmission for codes? I have a ob2 scanner or would you have to have a different scan tool?
Thanks so much for the info.
About the transmission fluid I only used the amount that it took to refill the pan back up after dropping the pan and changing the filter. I used whatever type of fluid listed in the owner's manual.
About my scanner. I only use it when any type of light comes on any of my vehicle's dashboard. I have the instructions for it. But I can look it up on the net. It is the kind of scanner you can buy at AutoZone that hangs beside the counter.
The truck runs and looks great for its age. I have already replaced a lot of parts and made many repairs that does not have to do with the transmission or motor.
Thank you both so much for replying. If I can be of further assistance to you please just ask.
What is the Transmission fluid level when fully heated.
I ask this because the fluid expands with heat and will show over fill from a cold full fill on the dip stick.
if you are experiencing shutter in OD and light throttle when EGR is called to open under light throttle conditions, the cause is likely to be a faulty ignition coil.
This condition can sometimes case severe jerking and harshness because the trans is already in gear when the PCM interrupts processing to the engine.
Upon down shift, the action will go away until the next time.
The actual cause of these actions is cylinder misfires because the EGR function presents a very lean mixture a faulty coil cannot fire.
The best way to find this is with a Scanner looking at mode 6, test 53. This program location is a record of misfires for all cylinders. Any cylinder that shows a count high and out of limits should have the coil replaced.
Check hot TX fluid level and for misfires.
Good luck.
Good luck.
Ford4me302
01-28-2004 08:49 PM
