Powder coat OEM wheel - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 10-13-2018, 09:23 PM
tdsutton's Avatar
tdsutton
tdsutton is offline
tdsutton is starting off with a positive reputation.
Has anyone powder coated their 2017-18 F250 OEM chrome wheels? If so can you post pics? Thinking about getting mine power coated gloss black. Also thinking about power coating my stock exhaust tips gloss black.
Old 10-13-2018, 09:26 PM
tdsutton's Avatar
tdsutton
tdsutton is offline
OEM wheel
OEM wheel that I want to get powder coated gloss black
Old 10-13-2018, 09:34 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
Powder coating PVD Chrome probably not going to work well. Plus if chrome yes, not the aluminum PVD rims IMHO.
Old 10-13-2018, 09:50 PM
tdsutton's Avatar
tdsutton
tdsutton is offline
Is there a reason you think the PVD is not a good idea to powder coat?
Old 10-13-2018, 10:08 PM
CBEllis's Avatar
CBEllis
CBEllis is offline
CBEllis is starting off with a positive reputation.
A good shop can do it. My local guy recommened satin black (vs. matte vs. gloss) so that's what I'm probably gonna go with.
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to behold
Well PVD is already technically powdercoated. So you would have to blast the wheels or it will not work when in the oven. Also the exhaust tip is going to be very cost prohibitive to powder coat simply based on the size and how expensive high heat powdercoat is.
Old 10-13-2018, 10:14 PM
tdsutton's Avatar
tdsutton
tdsutton is offline
Good to know, send me a photo when you have it done.
Old 10-13-2018, 10:17 PM
tdsutton's Avatar
tdsutton
tdsutton is offline
Didnít think about the size of exhaust, I might just go with the MagnaFlow exhaust with the black tips instead. Just weighing my options, thanks for the input.
Old 10-13-2018, 11:16 PM
Skikrazee
Skikrazee is offline
Skikrazee is starting off with a positive reputation.
I really like the look of your truck, I'm slowly trying to delete the chrome on mine too. did you have all of your parts painted or vinyl wrapped?
Old 10-13-2018, 11:24 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
How do you etch the Chrome PVD to allow the PowderCoating to adhere? There are posts where the PVD peels off. Maybe better to remove it entirely. To me, a more reliable solution is a set of aftermarket black rims. I like the look of them too. But I ain’t letting Ford off the hook on warranty with the PVD.
Old 10-13-2018, 11:25 PM
tdsutton's Avatar
tdsutton
tdsutton is offline
Thanks! It is all painted. The front and rear bumper, mirror caps and grille are painted body color. The front and rear emblems and fender emblems are painted two tone, body color and gloss black.
Old 10-14-2018, 06:11 AM
wildcard30's Avatar
wildcard30
wildcard30 is offline
wildcard30 is gaining momentum as a positive member of FTE.wildcard30 is gaining momentum as a positive member of FTE.
Being thinking about doing the same thing with my 20Ē PVD wheels. I guess it will all come done to the cost per wheel to get them powder coated. Iím sure the cost will go up if the PVD is a pain to strip off.
Iíve been looking at wheels and what I find that I like is about 1100.00.
So if the powder coating is close to that, it may be better to go with new wheel.
Subscribed.
Old 10-14-2018, 06:50 AM
vib8r
vib8r is offline
vib8r is starting off with a positive reputation.
Any wheel has to be sand blasted if you want the powder coating to last. Also, any wheel can be done including a PVD finish.
The only issue is when a chrome wheel has the finish peeling. Sometimes it is very had to remove all the chrome to get a good finish.
Your powder coating guy is correct, try and stay away from a gloss finish because it is like paint on a car and shows all flaws.
A matte (not flat) or satin finish is best for wheels.
Old 10-14-2018, 07:24 AM
CO Wapiti's Avatar
CO Wapiti
CO Wapiti is offline
CO Wapiti is starting off with a positive reputation.
A friend of mine had his wheels on his Super Duty powder coated matte black a couple of years ago. I didn’t think it would look good for long but 2 years and many miles later, thy still look great. They were painted steel wheels though.
Old 10-14-2018, 07:42 AM
vib8r
vib8r is offline
Originally Posted by CO Wapiti View Post
A friend of mine had his wheels on his Super Duty powder coated matte black a couple of years ago. I didnít think it would look good for long but 2 years and many miles later, thy still look great. They were painted steel wheels though.
How the powder coat looks after years of service just depends on how they are taken care of. Any finish can go to crap if they are not looked after.
Also, the wheels have to be prepped right! Just a phosphate wash does not do it. The wheels have to be sand blasted to get a clean etched surface.
Just make sure the sand blaster is careful when doing aluminum wheels. You do not want to sand blast so aggressive that you go past the flat casting
surface into the casting pours. When you get into the pours it is hard to get a good finish because the pours open when heated and produce air pimples
under the finish.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
