352 to 410
Sonic test your block and see if it will take an .050" overbore.
If yes, bore it.
Get a 428 crank and rods, or a 428 crank and rods out of an actual 410 Mercury. Rods can come out of any other regular production FE except 352/360. Cranks are available aftermarket.
Get 410 Mercury pistons, or if that confuses the parts person, get pistons for a 1970s Ford pickup 390. Confirm the compression height to be approximately 1.66".
Have the entire rotating assembly balanced.
So now you have a bored and stroked 352 which displaces 410.
You can't "make" it a Mercury only, '66 & '67 410.
This info is from the 1960s car FE engines:
FE Series Engine Specification Chart
428s and 410s are a bit hard to find, so you can get an aftermarket crank. If you do find something with a 428 crank, it is either a 428 or 410, or possibly something cobbed together by someone else previously. If it is a 428 or 410, just buy that whole motor lock stock and barrel, and work with that.
If yes, bore it.
Turning a 352 into a 390 = Relatively easy and not terribly expensive, and is a noticeable difference in power over a 352.
Turning a 352 into a 410 = More machine work required, finding a 428 crank is getting harder and more expensive, there's not a lot of difference over the 390 in power.
A good friend of mine went the 410 route, I chose the 390 route. In the end we both agree the 410 wasn't worth it.
I built a 410 and it runs well. That said, I would never do it again.
By the time I had the crank purchased ($250), ground, rods sized, forged pistons bought (only option to get the compression around 9.3:1 to run pump gas), and had the assembly balanced, I was within a couple hundred dollars of a 445 stoker kit.
If you want more than a 390, just get the 445 kit.
If you build a 410, it's pretty much mandatory - so yes, it takes more machine work.
4.25 stroke is not too much for a 352, btw. You can actually go to 4.375 stroke but at that point you have to start being careful for things like rods hitting the cam tunnel.
