New to me 6.0!!
#91
Originally Posted by bismic
I would at least pick up a MAP sensor from the junk yard and try it. Or you might find a friend that would let you try theirs.
All that is assuming that the code isn't from you disconnecting it.
#92
https://www.tascaparts.com/oem-parts...or-2l1z9f479aa
2L1Z-9F479-AA
$66 - assuming the harness checks out ok (and you are absolutely sure the hose isn't plugged or leaking and the nipple on the intake manifold isn't plugged).
2L1Z-9F479-AA
#93
2L1Z-9F479-AA
2L1Z-9F479-AA
#95
#96
Manteca , nor Cal we have a few truck only salvage yards up here , I found this info from Rusty axlerod , thanks Eric great info and when I’m out of Reps jail I’ll catch you
https://www.ford-trucks.com/forums/1...t-harness.html
#98
#99
So after I messed with the icp harness I noticed at idle it sounded a lot smoother, I'd rev it and I'd hear boost; more than I normally do. So I took it on the road and man it drove smoother than I've ever seen it. I got up to 75 going on a decline. After about 2-3 miles cruising it started acting up the way it always has, missing and surging. I pulled over, wiggled the connector and harness in that area and I was able to cruise at 40 on the way back up hill missing and bucking. On the way back I noticed the desired and actual from the icp at wot we're both fluctuating opposite of each other. Meaning when actual was at 1k desired was at 2k and vise versa. Could that just be because it's missing tho?
Also I noticed the internal plug inside the icp connector was loose, it was able to slide up and down inside the sensor!! Is that normal?
#101
Originally Posted by xcrsp440
Did you replace either the sensor or pigtail already?
#102
#103
Originally Posted by 04badford
T
This is my ICP connection , under the grey clip it was shorting out , its a white mark on the inside of the three wires , no play in the connection what so ever , that could be your issue , mine only acted up when the engine was warm/ hot temp ,
Here's my pigtail, looks like it's missing some pieces.
Also the white part inside my icp sensor , the one in the picture, is the part that moves up and down inside the plug,
#104
LADIES AND GENTS! Announcement please!!!!
It is now drivable!!!! I have driven the truck 10+ miles at 80mph!!!!
Still feel it missing and a little surging at top end of gears but once it shifts it's fine till the next gear. If I give it wot I don't really feel any missing.
ISSUE NOW! ---
It's boosting! But I have -0 on the boost gauge! And I cannot clear a p0237 code. It immediately comes back. We're almost there people!!! I can feel it!
ISSUE NOW! ---
#105
