Just in case it happens to you. - Ford Truck Enthusiasts Forums
Old 10-11-2018, 08:00 PM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
jimjokjv has a good reputation on FTE.jimjokjv has a good reputation on FTE.
Drove my truck to the store today. When I got ready to leave it stalled (a first) but started right back up and then stalled again. I immediately checked the fuel gauge and I was in uncharted territory as the needle sat right at 1/4 of tank. I'm one of those that keeps the top half of the tank full so never been this low before.
Having read stories about broken fuel pickups not reaching the bottom of the tank I sent for more fuel. When my friend arrived we poured a couple of gallons in and the truck fired right up. Off to the gas station to put some more diesel in.
Pulling out of the gas station it stalled again. Now I am in a bit of a panic.
Remembering that I had recently pulled the 42 pin wiring harness I started inspecting all the connectors thinking maybe something was loose. Once again the truck fired right up and I drove it 8 miles into town with no issues but then it started bucking and acting like someone was turning the ignition key on and off rapidly. Slowed to a crawl and then it stalled.
Started it again and crawled along for a while before being able to accelerate. It definitely sounded fuel related and I decided to check the pre-pump filter I had installed. Diesel flowed all down my arms and soaked my jacket. This wasn't the problem.
Went back up under the hood with a flashlight and inspected every inch of the harness when I noticed something amiss. The drain valve for the fuel filter was partially open. Could it be that simple? Yes, it can! Once I had fully closed the valve my truck starting running like a champ again.
Apparently I had caught the wiring harness on the drain valve handle and pulled it partially open without realizing it.
Feeling very relieved right now as I was expecting big money issues.
Old 10-11-2018, 08:30 PM
PrescottIce's Avatar
PrescottIce
PrescottIce is online now
PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.
Dang, I love easy fixes like that!
Having taken a Diesel bath today (installing a pre-pump filter), I empathize with the results of your diagnostics.
Old 10-11-2018, 08:43 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
Sometimes itís the simple things/ simple mistakes that give us the most pucker factor. You will never forget it and I am glad you got her up and running. Just like the pumps on our fire trucks, you leave even a small drain open and it effects the pressure quickly.
I shorted out a screwdriver on the alternator by accident one time. Melted it in half and caught some wire loom on fire. The screwdriver sits on the work bench where I see it every time. Memory markers go a long way.
Old 10-11-2018, 10:32 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Reps.
Stewart
Old 10-11-2018, 11:09 PM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
Prescott, AZ
I live in Paulden so not far away.
Old 10-12-2018, 09:25 AM
mcnance865
mcnance865 is offline
mcnance865 is gaining momentum as a positive member of FTE.
That fuel drain valve is also a common problem. Eventually it will wear out and start to leak. May need replacing. Not a big job. Just something to remember.
Old 10-12-2018, 10:52 AM
'88 E-350
'88 E-350 is offline
'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.
I can't think of any reason that the valve not being fully closed would do this. My guess is it was a harness/connection that you fiddled with and not the valve. It's remotely possible that the foot is bad and that there was still air trapped in the system, but an electrical issue is more likely.
I suggest going back over the harnesses/connections with the engine running to see if you can pinpoint where the issue is so it doesn't get worse. And to eliminate the fuel valve as a potential culprit you can move it back to where it was with the engine running to see that it won't make it stall. You'd have to open it enough to have an obvious fuel leak before it would cause the engine to stall, I'm not even sure it could flow enough to kill the engine with the valve wide open.
Old 10-12-2018, 11:30 AM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
Thanks. I will be driving the truck this morning and once it is warm I'll try wiggling some of the connectors to see if anything happens.
A number of years ago I had a car start acting like this. Too much accelerator and it would die, driving at speeds it would start chugging and begin to slow down, stall but restart and idle okay, etc. That turned out to be a clogged fuel filter. These symptoms are nearly identical. Hence my suspicion that the fuel was not flowing properly through the system.
When I had first discovered the valve half open, I tried to turning it more open and it caused the truck to run worse, when I closed the valve it ran much better. Hopefully my drive today will verify one or the other.
Old 10-12-2018, 06:14 PM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
My hats off to ya! Truck ran great all day and when I got home I decided just for grins to check each connector. Sure enough the black connector to the Glow Plug Control Module was just barely making contact. All I did was touch the wire and the truck began to misfire.
Turns out it wasn't seated completely because of a twisted seal.
I fixed that and then added some wire ties to make sure those connectors don't back out again.
I guess only those with the California emissions (read: Glow Plug Control Module) would ever run into this problem.
Thanks again for your insight and instructions.
Old 10-13-2018, 01:52 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Thanks for the reminder on ties to secure the GPCM plugs. Top of my truck PM schedule.
Old 10-13-2018, 03:22 PM
dn29626's Avatar
dn29626
dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
Glad you got it.
Old 10-13-2018, 03:25 PM
Stewart_H's Avatar
Stewart_H
Reps revoked for previous reason being invalidated. (ok I can't really do that, but we'll pretend)
New reps given for correct fix being posted. (Again, we'll pretend) It all evens out in the end!
Stewart
Old 10-13-2018, 07:05 PM
hydro man 17
hydro man 17 is online now
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
I have always been under the impression the the GPCM is just fancy GPR that feeds power to the GP's individually. I had to replace mine as one bank was bad but it would start and run fine unless it was pretty cold, but even then it would just romp for a few seconds and clear up.
Old 10-13-2018, 09:38 PM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
Stewart
Ha,ha. I sincerely thought I had found the problem. Truck ran perfect until I started wiggling connectors.
Sorry for the extra work!
Old 10-14-2018, 11:03 AM
helifixer's Avatar
helifixer
helifixer is offline
helifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputation
Prescott, AZ
I feel like the middle man, I live in Chino Valley.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service About Us
© 2018 MH Sub I, LLC dba Internet Brands
