Turbo rebuild Help Can i Use it? - Ford Truck Enthusiasts Forums
Old 10-11-2018, 09:45 AM
microdevil45's Avatar
microdevil45
microdevil45 is offline
microdevil45 is gaining momentum as a positive member of FTE.
So a picture is worth a thousand words right! So my biggest question is Can it be used or do I need to replace it? I do have a spare from a van turbo so i could potentially use that one. Thoughts?
Old 10-11-2018, 10:05 AM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
Can or can’t … rather I wouldn’t but that’s me.
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.
Yes, the lip is a register not a seal.
Old 10-11-2018, 08:10 PM
PrescottIce's Avatar
PrescottIce
PrescottIce is offline
PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.
What? You missed the "yeah, the turbo has a chunk out of it, time for an upgrade..."
Old 10-11-2018, 08:25 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
I think what pirate is trying to say is you can see in the picture where the o ring sits. Oil to the inside, only mounting bolts to the outside. The part that is broke is used for alingement for the two parts mating together. If on a tight budget I think I would try it, it doesn’t take that long to pull the turbo anyways.
If not put an wanted ad in the marketplace. Lots of guys have upgrade turbo so and the stock ones are sitting on the shelf in the garage.
Old 10-11-2018, 09:03 PM
akcooper9's Avatar
akcooper9
akcooper9 is offline
akcooper9 has a good reputation on FTE.akcooper9 has a good reputation on FTE.
I have a stock one with 100K on it looking for a new home
Old 10-11-2018, 10:18 PM
pirate4x4_camo
Your broken one will work but if you want to replace it Riffraff sells a new center hub for $128.
Old 10-11-2018, 10:20 PM
Wesley Green's Avatar
Wesley Green
Wesley Green is online now
Wesley Green has a good reputation on FTE.Wesley Green has a good reputation on FTE.Wesley Green has a good reputation on FTE.
"Sorry dear, the internet gurus say its toast and I'll have to replace it with a T4"
Old 10-11-2018, 10:52 PM
Firefighter 1406
And we have a winner!!
Old 10-15-2018, 07:36 AM
microdevil45
Thanks for all the feedback, I ended up using the spare one from a van turbo I had laying around. I did reassemble the van turbo using this centerpiece and it does only look like alignment because the backplate fills in the hole when together. The T4 is an upgrade i have been looking at down the road, this was just to fix a bad o ring on the ped and happen to noticed it.
Old 10-15-2018, 08:31 AM
Dan V
Dan V is offline
Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.
I have a modded stock turbo on the shelf recently as well. 1.0 non-wastegated housing, DieselSite WW2, EBV delete ped, Dorman uppies.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
