Aerostar Ford Aerostar
95 Aerostar Electrical Issue
Old Oct 11, 2018 | 05:46 AM
biashara's Avatar
biashara
Hi Everyone,
I hope all is well with y'all.
My 95 Aerostar with over 250K miles has been making me scratch my head. I recently had the shifter cable replaced after the gear lever stopped engaging.
Soon afterwards,
~Turn signal/multi-switch doesn't work though the flash/hazard lights work,
~Radio and A/C doesn't work
~Reverse lights don't work
I have checked the fuses and all are intact, so are the bulbs on the said lights.
I cleaned grounds( Found one attached to vehicle body under hood and other one by engine block.)
I also had the ignition switch and cylinder replaced but the issue still persists.
Any leads/info to getting this corrected will be highly appreciated.
Thanks
Old Oct 12, 2018 | 04:42 PM
93nighthawk's Avatar
93nighthawk
I would say bad ignition switch/not fully seated, or a wiring issue because all those wires run along the ignition switch in the column.
Old Jun 1, 2020 | 09:37 AM
tp4pdb's Avatar
tp4pdb
biashara,
Were you able to fix your problem? I have a similar problem with my '91 Aero. No turn signals or back-up lights. Fuse okay. Hazards work.
Thanks
dylan8427
Sep 8, 2012 08:14 AM
larrylass
Aug 30, 2012 12:26 PM
198769ford
Feb 22, 2012 11:47 AM
sitdog84
Jan 18, 2011 09:51 PM
daggerNC
Dec 11, 2010 11:50 PM
