1977 Ford Ranger 351m/400 blown head gasket.
Hello to all! I am in the process of restoring a 77 Ford Ranger with a 351m/400 not sure which one it is. long story short the truck has been sitting for quite some time. the engine would smoke pretty bad the first couple times I started it up. since then I have replaced the head gaskets on both/ changed the oil and now it doesn't smoke anymore. The oil is milky again but I believe that is because the pan is really dirty and still has coolant left over in the pan. My coolant level seems fine! I had a mechanic look at it the other day he told me I shouldn't have replaced the head gaskets without resurfacing the heads because it will just blow again. Should I resurface the heads? how much would that run me? Its already bad enough the c6 transmission in the truck wont go into reverse. I have to pick up a used c6 trans from a 460 for 400 bucks. Right now I am not looking for any performance gains. I just want the truck on the road.
I did not! I was going to call a machine shop today and get a quote. If it’s too expensive I might try and find a used set of heads at the junkyard. Would that be a good idea? Or is it better just to stick with my heads that I have? I hope the block itself doesn’t have a crack in it.
ohiofossil
03-04-2006 10:38 PM
